WANTED - N/S Front Caliper
x 82
hmmm, think i know what i did to fubar the caliper! Ooops, might need the Citroen tool 228-T to fix it (around page 280 of the old haynes should give it away!), and while it doesnt look to hard to overcome, think i'll just get a replacement, any offers??
Need it in liverpool/cheshire preferably without the caliper frame bit.
DLM
Our Trim Guru
Post by DLM »
Citroen tool 228-T ? Would that be the one for compressing the spring washers?
If so, then you can overcome the problem with a sturdy vice and a screwdriver......as I found when I stupidly removed the cross-bar on a front caliper.
x 82
thats the one, stupidly removed the cross member, shoved everything back together!
can probably fix it, but im rapidly running out of parts if i screw it up again!
However i did by the pentagon socket for £3 so that speeds things up!
x 82
](*,) still dont have one :(
bernie
Likes welding rusty Fiats.
Post by bernie »
I've got one Vanny :)
What's the latest on the Laptop from your friend? :?
Just the 0 BX
1 TZD Turbo a/c going going GONE
1 TD Hurricane being broken up for spares
3 FIAT 124 Sports!!!
1 FIAT 124 Spider ex. California
Oh and I nearly forgot
A LOVELY XANTIA HDI EXCLUSIVE ESTATE
Keeper of the site Goat
Post by cavmad »
How soon do you need it Vanny? I`ll almost certainly have one though probably not for 2-3 weeks.
Vauxhall apologist.
Post by ken newbold »
I may have one. I know I have several but all the same side, dont know which side :oops: trouble is they're burried deep in the garage, thats why I haven't responded before, I figured by the time I'd dug it out you'd have probably got one. Theres one in a local scrappies, probably get it for a tenner, let me know.
Ken
