How long does yours stay up!
Post by ken newbold »
Mine stays up overnight now :o
Well it does now that it's got it's new rear cylinders on and height corrector problems sorted. Even with a boot full of junk. :idea:
Well what did you think I was on about. :lol:
Ian_Fearn
Post by Ian_Fearn »
GTi: Dropped to the floor in a couple of hours
TZD: Stays up for a week
Over and out from me
Terry Brooks
Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Post by Terry Brooks »
My TZD? ......about half hour,less if the tanks full of deisel.
tim leech
Post by tim leech »
No idea, its away in the garage under a sheet for weeks on end. The 14E would stay up for days.
Valver stays up for about half a day. The estate used to sink at the rear after a day, but would stay up for a week at the front!
tim leech
Post by tim leech »
Saddo that I am I miss seeing bxs about now with tha front end poining skywards!
OwenS
Post by OwenS »
I can't even get mine up at the moment!! :shock:
2007 Sportka
OwenS wrote:I can't even get mine up at the moment!! :shock:
Perhaps you need some Viag in your LHM stream? :wink:
OwenS
Post by OwenS »
Haha! thats something I haven't tried!!
2007 Sportka
stuart_hedges
Post by stuart_hedges »
Sally used to settle nose first, but seems to do it the other way around now. BXs always seem to settle arse first!
soxer123
Is it good or bad ?
Post by soxer123 »
Is it a good or bad sign that the suspension stays up (if that is what you are on about) ?
Mine drops at the rear after a couple of hours and about a day on the front.
KP
1990 BX Meteor 55k
Outside of a dog, a book is a man's best friend. Inside of a dog, it's too dark to read - Groucho Marx
stuart_hedges
They all seem to behave differently, soxer, but from my experience of BXs that seems about right! As long as it rises smoothly without nasty noises or jerks and the pump doesn't tick too often you're probably OK.
I've always been led to believe its better if they sink quickly, aslong as they aren't leaking etc. I'm sure the reason the estate stays up is stick struts! :lol:
tom
Citroen Sorceror
x 38
Post by tom »
Yes, I agree. The car should remain up all night unless it is windy or very hot. The front should sink at a similar rate if the struts are not binding. For the record, My tick time is 3 minutes and the sink time is greater than 36 hours at the back following replacement of Doseur, rear HC and accumulator sphere so that's about as good as it is likely to get. This can be confusing; cars that rise immediately from cold are regarded as good when it really means that their spheres have failed!
Does it matter if it goes arse end down 1st apart from looking daft?
