Rear wiper differences?
Had a few BX`s now and one thing that puzzles me is this: some have rear wipers that when you press the button on the dash once will work on an intermittent setting and others have to be pressed everytime you want it to wipe and then only wipe once.
Is this something to do with the switch or the wiper motor itself?
Vauxhall apologist.
- x 88
AFAIK the estates have the switch that stays on, and the hatches have the 'push to foot' switch.
I learnt that on here about a month or so ago Its just the swtich IIRC.
- x 88
With an estate switch it would just go constantly unless you fitted the relay.cavmad wrote:capri wrote:So would it be possible to fit an estate switch to a hatch in order to make it come on intermittently?
Just what I was thinking!
I`m guessing the realy will be somewhere near the wiper motor inside the boot then?Kitch wrote:With an estate switch it would just go constantly unless you fitted the relay.cavmad wrote:capri wrote:So would it be possible to fit an estate switch to a hatch in order to make it come on intermittently?
Vauxhall apologist.
- x 88
You would think, but being a BX it'll be behind a side repeater or somethingcavmad wrote:I`m guessing the realy will be somewhere near the wiper motor inside the boot then?Kitch wrote:With an estate switch it would just go constantly unless you fitted the relay.cavmad wrote:
Might be in the fuse box?
Hi!
All BX Serie2 hatchback that were produced until 1987 had the intermitted rear wiper function. Later on this feature disappeared and survived for the estates. The relay for this is somewhere near the upper glove-box (you didnt have this on RHD-BX, i know) so it should be somewhere on the left of the steering wheel.
So just changing the switch doesnt make any sense... You will need the relay with its wires.
>>Frederic
>>Frederic
- mnde
- Meteor Man
Yes, but when you're trying to do a complicated reversing manoeuver in the pouring rain, it would be nice to have an intermittent or constant rear wipe, cos you need both hands on't wheel, not one groping for the damn switch and sending even more water all over the rear screen!Stewart (oily!) wrote:never owned an estate, but I have had a BX with a latching switch, really its unnecessary,
over 40 mph no rain lands on the rear glass of a BX hatch.
Stewart
Mark.
What a grumpy reply MNDE
Mind you the BX is not one of the best cars for rearward visibility anyway, especially with the spoiler in the way, but the high bootlid really does not help, compared to things like the ZX rear vis is really rather poor.
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
- Barnsley BXer
If you want poor rear vision,try a Xsara.My girlfriends got one and it's shocking.Give me a BX every timeStewart (oily!) wrote:What a grumpy reply MNDE
Stewart
1990 GTI 4x4
1992 TZD
1992 TZD
- mnde
- Meteor Man
Thankyou Just one of those things that irritates me about my BX. Mind you, the old one was even worse: the wiper became sluggish and would often come to a halt in mid-wipe! Even the base model GSA comes with rear intermittent *and* wash/wipe Similarly, it's not really needed at speed because of the aerodynamic water-clearing effect.Stewart (oily!) wrote:What a grumpy reply MNDE
Stewart
Mark.
