How do I get the heater dial panel off!?
simonineaston
Post by simonineaston »
Confession-time here, folks - I've read another thread on this forum explaing how to get this panel off, but I didn't get it! I've got as far as A) removing all three dials (ping! go the little spring-steel clips onto the floor...) B) removing the 2 grey screws (mine were Philips head, which was a bit of a surprise in view of the fact that all the other's I've met so far have been Star or Torx or whatever they're called...) C) pulling out the 2 vent grills and after peering inside the resulting hole - I'm stuck! What next!?
Simon, Bristol UK
('91 TZD 1.7)
tom
Citroen Sorceror
x 38
Post by tom »
Grilles out, look down the hole. an inch down the hole, on the vertical surface there is a slot. Poke a wide screwdriver in and lever the clip inwards, toward the centre line of the car. Pull panel towards you. Repeat for other side. Disconnect lighter. If PCB marked "ELEDASA", modify before replacing.
simonineaston
Cheers :-) Why do I modify the pcb you refer to - and how!?
Simon, Bristol UK
('91 TZD 1.7)
tom
Citroen Sorceror
x 38
Post by tom »
The ELEDASA board had a design fault and somewhere on this site is the necessary info to mod it in order to allow the fan to run at full speed.I'll see if I can remember where it is.
Its easy.....on the front of the board there are lots of metallic strips, and the one closest to the dial has a little dark coloured panel between two of the contacts. Flip the PCB over and solder a wire between the two, bridging the little panel type chap in the process.
tom
Citroen Sorceror
x 38
Post by tom »
NO! That is not it. I'll just have to find the correct posting...
http://www.frenchcarforum.co.uk/forum/v ... php?t=6133
This is quite a long thread but the data is about half way down page 2 posted by one Tomsheppard. The web reference no longer exists but the pictures were uploaded to a scandinavian site some time ago so if you really need a picture, googleit up.
Doz
Post by Doz »
See the drill hole that breaks the track between the 3rd and 4th pins (counting from right to left) ... as I see it this is the one to bridge ...
The little black panel looks like a thick film ... don't bridge that one...
damned if I can fine the Scandinavian website ....
Please correct me if I'm wrong ...
Doz
2007 Citroen C1 (it's not a real Citroen)(With a complete set of wheel trims)
2006 C4 1.6VTR+ (Alloys no wheel trims)
1982 Mini HL (No wheel trims, no wheels)
1993 Kawasaki GPZ500
Doz
Post by Doz »
PS ... change the bulbs while you're in there .....
Doz
Ah I thought it was. Oh well
tom
Citroen Sorceror
x 38
Post by tom »
NO!
Link the gap in the track fourth from bottom beneath the black resistive track, then cut the thin vertical track below the left hand side of the black resistive track.
Thanks for the picture Doz!
Would earlier posters on this thread please amend their erroneous posts and then the mods could make this one a sticky if they feel so inclined.
Post by jeremy »
Tom's right - worked well on mine and I found the full fan speed complete with relay above the steering column which worked despite about 15 years of idleness!
While you've got it apart it may be worth cleaning the contacts on the rheostat wiper and making sure its got enough tension.
If you are changing the bulbs its also worth checking they work before re-assembly as some can be a bit temperamental (in my case probably cheap and nasty)
Doz
Post by Doz »
When I get home tonight I'll mod the picture and post it up, then we hav the definative mod...
Doz
simonineaston
That's why I'm going there :-)
Thanks for all the lively discussion folks! I think I've got me head round it...
Simon, Bristol UK
('91 TZD 1.7)
Doz
Post by Doz »
So I think this is it then...
Doz
tom wrote:NO!
NO!
