Something like these may help get the manifold nuts off.
http://www.machinemart.co.uk/shop/produ ... t-grip-set
I think they're bolts rather than studs which means that if you're lucky the bolts will snap off. If you have a MIG it may be possible to weld something on to enable you to grip the nuts - and in fact the welding temperature will probably enable the nut to be undone when it cools.
I'm not sure what the access is like byt again it may be possible to get a drill on the nut and drill it out. Takes a steady hand to drill the bolt endways but it can be done.
Another one
- x 94
- x 94
- x 94
