Another cambelt failure, on 1.6 Meteor.
jrdpod
- x 41
I 've had the cambelt tensioner fail. The cambelt is still on, but is loose.
Like Andycadabra, this happened at a low speed, and the symptoms were a sudden increase in "valve clatter", followed by loss of power.
The car has gone to my mechanic. It's currently being assessed to see if new valves/pistons or head are needed.
He says it is "repairable".
He would be able to carry out repairs at "trade" price, but I could be looking at a bill of up to £400.
The engine has done 113K. Apart from this problem, the rest of the car is "in good condition".
John Podgorski/n586ua.
John R D Podgorski
BCXM
mnde
- Meteor Man
Out of interest, how loose is loose?
I actually checked the cambelt on my non-starting Meteor to try and rule out this as a cause of my own breakdown; see http://bxclub.co.uk/forum/viewtopic.php?t=6046.
It was changed at the end of last year, but the tensioner wasn't done because I was told it was fine and "they never go". I removed the top cover last week and found the cambelt to be surprisingly slack under thumb pressure and I could prise it back and forth across the camshaft drivesprocket teeth with my fingernails.
The only reason I half suspected this was that when the car stalled the first time, it was while I was letting someone cross infront of the car and I thought I hadn't given it quite enough gas to pull away again, so I changed into 2nd or 3rd and tried to bump start again using my forward momentum - which didn't work - and then the engine wouldn't restart. I've vaguely heard of cambelts failing or "jumping teeth" under stalling circumstances like this. But the few times the car did start after I'd pushed it into a parking space, the engine seemed to be running fine and then suddenly cut out as I described, which pointed to a coil/amplifier fault. I'm still stumped by this.
How tight is the cambelt supposed to be? Is it supposed to be something like "can be twisted through a max of 180 degrees in the middle of it's longest length of travel"?
DavidRutherford
- BX Digit man!
substitute 90 degrees there, and that's spot on. Or at least it's certainly how I've set cambelts for the last 15 years. If there's detectable slack, then it's too loose. If you can play a tune on it, then it's possibly a little tight. If you can grab hold of it along the longest straight, and just about twist it through 90 degrees before your fingers go white and fall off, then it's about right.mnde wrote: Is it supposed to be something like "can be twisted through a max of 180 degrees in the middle of it's longest length of travel"?
Electronic belt tension checkers are a load of rubbish. You can fool them into telling you anything. I've managed to get one to tell me that a belt is massively too tight, and then too loose simply by turning the engine over a bit more.
Yep, agrre with David 100%. SEEM meters are crap, dont even bother. 90 deg is fine, unless it's a 16v in which case 45deg is what you want on the longest run.
You MIGHT get away with just aligning everything and fitting a new belt / tensioner, but it;s probably got some bent valves in all honesty...
jrdpod
- x 41
Another cambelt failure, BX 16 Meteor
The fault has now been fixed.
All that was needed was a new belt and tensioner, parts cost £53 (trade).
With labour, the final bill is about £120.
The old belt had jumped two teeth on the sprocket.
No engine damage was caused, and I'm very lucky, i't's a good thing I "killed" the engine immediately I realised something was very wrong.
The moral of this story is;
If you get a used, high mileage car, with little or no history, ALWAYS CHECK THE CAMBELT, and REPLACE IF IN DOUBT !!!!
Regards
John Podgorski/jrdpod.
Regards
John R D Podgorski
BCXM
Barnsley BXer
tim leech
Seconded, you were lucky jrpod, I wasnt at a full head rebuild was needed on mine! Costing twice what the car costdocchevron1472 wrote:First thing I do when getting a car is full service / brakes / cambelt before it goes anywhere near a road. It really does make sense.
tim leech
tim leech
I'm impressed! I take it you now have "welders tan"?
and I hope there is no evidence of "pigeon poo" welding....
I shall be inspecting at the national...the car that is.
