It happens when going some speed bumps and when going quickly over some rough roads
And only on the drivers side
I’m not sure if it’s coming from the rear roll bar or the swing arm bearings
Hi there. There are arm bearing kits on ebay at the moment. The only way to do it as they include everything.classic2cv wrote:I have a spare pair of good arms so I can do the bearing later
Spot on Michael. Well explained. Just because its a citroen doesnt mean a complicated job. I recently did my first one and approached it with reservations, (as you do) but even I managed it with no drama and am now looking with much more frienliness at my other four BX's as they probably ALL need a looking at in the department.m_2975 wrote:Hi there. There are arm bearing kits on ebay at the moment. The only way to do it as they include everything.classic2cv wrote:I have a spare pair of good arms so I can do the bearing later
Doing the arm bearings really isn't a big problem. The only thing that you need to make sure is that it's greased properly and that the outer seal is fitted correctly.
Back on stands, System depressurised, rear wheels off, inner brake shield off (not necessary but handy for extra room), brake pipe off, suspension cylinder pin out that goes through arm, (ABS sensor if you have disconnected either from arm or unclipped under back seat and pushed through) and big bolt undone. Then it all falls out and you can take the arm out, knock the bearing out by using a screwdriver to push the central metal tube out and then gently remove all the other smal bits inside. Then refit as per Haynes or just ask.
Michael
I'm always here to helpclassic2cv wrote:this is cool![]()
i ask a tech question and i get 2 answers from down under![]()
That's a great idea David as we all know how easily and fast a site can disappear from our midst!ellevie wrote:I've made an offline version of it with correctly referenced http links just in case it should disappear one day.
