Basically we have a nice sized (all be it single) warm, dry garage here at home. However TVR's leak like seives and are not designed for the weather the ironically surrounds the country that made them! So it's now in said garage. The BX was sitting in there, but due to the fact it's getting on a bit and is starting to rot in small places now, I wanted to also garage it so I rented a garage in a block on the outskirts of Southampton for it.
Problem is it looks like with all the heavy rain, the garage is leaking! It's got a make-shift drainage system in the concrete floor down one side which fills up, although it doesn't seem to over flow. It's also damp on the other side and water is lightly dripping through the roof onto the car. When I put the car in there a couple of weeks ago, I also put my watertight cover on it, so the dripping isn't as issue.
What I'm now worrying about is that will this wetness cause more issues than before? If theres no air getting in then I'm guessing the floor will take ages to dry and surround the car in damp? That said, it's got to be ten times dryer in there than outside so is it still a good idea anyway? I'm renting it very very cheaply off a mate and I can't really keep it on the driveway here as it means parking a car on the road, and there isn't much kerb space as I now live in a cul-de-sac.
Ideas? Is the valver in danger?
[/img]
