Need a speedo
optimist
Need a speedo
Hi I bought a diesel meteor in Dec '07 with a dysfunctional speedo.After reading a few posts regarding cable problems etc. I checked the cables. grrr.Anway these seem to be in good order so it appears that the cables are not the problem.The speedo itself was stuck at 45mph and I suspect it is the unit itself that is the problem.So Iam looking for the whole assembly.as this is an auto box diesel there is no rev counter,just a nice big clock.Has anyone got this unit or could anyone point me in the right direction? I am oop north so locality is important.cheers.
tim leech
I have a BRAND new speedo in a Citroen box 000000 miles
if they are all the same you can have it for what it owes me which is £25, and I will post it to you for that. To be honest changing the speedo itself is not a difficult job, and you can replace all those blown dash bulbs aswell, All you need is a small screwdriver set and about a hours time.
tim leech
Sorry, I was being fesescious (sp)...
Ok, All speedo heads for Mk2's are the same (ish).
There are some gearing differences, and this is denoted by the number on the face of the speedo.
The long number can end 00 or 01 or 02.
00 and 01 are compatable, 02 is not compatable with any other head.
Whilst you can fit a 02 into any car, it'll read about 4mph out if the car had an 00 or 01 in it before like....
Brian
tim leech
