Many preciouses
BX 16v Ph2 - XPO - x 103
Many preciouses
All available, make me an offer!
see here for pictures;
http://s297.photobucket.com/albums/mm23 ... ar%20parts
Autolok - handbrake/gear lever lock
complete clocks (turbo diesel)
Genuine Citroen Tool set - 4501-T - AX rear beam repair kit
XUD7T pistons and crank
XUD7T oil pump
XUD7T bottom end (riffled bores, scrap)
multiple BX original jacks
XUD7 water thermostat housing (all bolts loosened
19rd pressure regulator
misc struts (possibly a total of four)
80 Amp 6 groove (Xantia) alternator
Xantia twin output 7 piston pump
pug 405 NA disesl injector pump
BX front calipers (regular)
19rd doseur valve
brand new GREY rear genuine rubber mats (where in my car for 3 days, then i got genuine black ones)
70amp 6 groove (xantia) alternator
TD intercooler feed pipe
TD front to rear metal coolant pipe (goes around the block)
AX scissor jack
hundreds of BX and AX switches
AX front slam panel
405 breather pipe
known good 50 amp alternator
Xantia TD aircon idler pulley
BX HP pulley (numerous)
XU lower engine mounts
XUD tacho pickup
XUD KKK Turbo - rubber pipes
XUD KKK turbo - hard plastic pipes
misc mud flaps
xantia hard plastic turbo feed hose
BX scuttle cover red
BX 16v? air intake panel
misc wheel bolts (non all
misc lighting components ( side repeaters etc)
HP pump mount
knobs (many more)
boot cover for reg plate lights
BX O/S wing shroud
fog light housings for bumper
worn (past best) energy tyre on good rim
random steering wheel (BX direct fitment)
fag lighter
gear box worm drive pickup
full set 405 hub caps
AX boot lining (good condition)
bx lhm reservoir
XUD engine mount
Citroen Genuine tool set 0187-ZZ (Xantia engine tools?)
XU braided water hose
405 N/A diesel glow plug relay
405 Air box
19rd air intake hose (picture shows worst end)
405 temp controls
405 oof console
405 door handle shrouds
405 sun visors (grey, set)
405 diesel engine wiring?
kenwood cross over units (set of 2)
405 estate aerial cable
bx16v steering rack
pug 309 drive shaft
misc XUD engine bolts
Multiple Haynes (more about showing off then offered for sale!)
rear brake calipers
interior parts (misc)
pug 405 stereo control
multiple BX switch units
more interior bits
pug 405 estate bumper and genuine towbar with electrics
pug earth cable (new)
BX pinion valve heat shield
BX rear wiper motor (SOLD)
bx boot lock unit
misc XUD injector pipes
BX track rod end
BX ABS pump
XUD tensioner ad xantia idler
XU engine pulleys and parts
405 dash clocks
BX rear clusters
Ax bonnet (taheti green)
BX Front ABS cable (SOLD)
BX rear arm abs cable holder
BX rear boot lock button
Old school / collectable Hoover vacuum cleaner (working condition!)
misc front BX lights (indicators/head lights)
XUD top mount intercoolers and manifolds
AX washer bottle
misc pipes
AX rear clusters
405 manual mirror (drivers)
AX column switches
405 estate rear cluster
XUD 7 head(inc bosch injectors) NO CAM/CARRIERS
405 head lights
BX front grill
AX scuttle cover
Adikt High alloy wheels (offers around £500)
405 parcel shelf (complete and working)
Xantia TD pipe
Panasonic CD head unit (offers around £60)
XUD Waxstat BRAND NEW
random pulley
XUD7T oil pump
19rd doseur valve
AX scissor jack
AX front slam panel
405 breather pipe
XUD tacho pickup
misc mud flaps
HP pump mount
knobs (many more)
BX O/S wing shroud
fag lighter
bx lhm reservoir
XUD engine mount
405 Air box
405 temp controls
405 oof console
bx16v steering rack
pug 309 drive shaft
rear brake calipers
more interior bits
bx boot lock unit
BX track rod end
BX ABS pump
405 dash clocks
BX rear clusters
AX washer bottle
misc pipes
AX rear clusters
AX column switches
405 head lights
BX front grill
AX scuttle cover
Xantia TD pipe
random pulley
TB2
mountainmanUK
- BXpat
macker37
- Keeper of the site Goat
CitroXim
- Sir Jim of the Databases
Re: Many preciouses
I'm interested in that one Vanny. Any further details?Vanny wrote: Citroen Genuine tool set 0187-ZZ (Xantia engine tools?)
EDIT: Can't tell a lot from the picture as the lid is shut
Jim
Todd, it came off my 19rd in i think 2002 when i scrapped it in favour of the valver. The brakes worked pretty damn well givent hat it had michelin energie 165s all round. Let me know where it needs to do to and i'll get you a price for postage (i use interparcel).
Macker, yes it will fit a 16v or any other BX, even has the indicator canceler on the back. Make me an offer via PM and its yours (the screws and the cap for the centre are with it, but ot in the picture).
Jim, will get more pictures, it does suggest what engines its for inside, think its for petrol engines, will get more pics early next week.
CitroXim
Brilliant! Thanks VannyVanny wrote: Jim, will get more pictures, it does suggest what engines its for inside, think its for petrol engines, will get more pics early next week.
Jim
roy.hassell
Wipeer Motors.
Also got Front and Rear Wiper Motors for the hatchback and their mounting brackets for sale. Please pm me.
Roy.
Roy.
