Many preciouses
x 82
Contact:
Many preciouses
All available, make me an offer!
see here for pictures;
http://s297.photobucket.com/albums/mm23 ... ar%20parts
Autolok - handbrake/gear lever lock
complete clocks (turbo diesel)
Genuine Citroen Tool set - 4501-T - AX rear beam repair kit
XUD7T pistons and crank
XUD7T oil pump
XUD7T bottom end (riffled bores, scrap)
multiple BX original jacks
XUD7 water thermostat housing (all bolts loosened
19rd pressure regulator
misc struts (possibly a total of four)
80 Amp 6 groove (Xantia) alternator
Xantia twin output 7 piston pump
pug 405 NA disesl injector pump
BX front calipers (regular)
19rd doseur valve
brand new GREY rear genuine rubber mats (where in my car for 3 days, then i got genuine black ones)
70amp 6 groove (xantia) alternator
TD intercooler feed pipe
TD front to rear metal coolant pipe (goes around the block)
AX scissor jack
hundreds of BX and AX switches
AX front slam panel
405 breather pipe
known good 50 amp alternator
Xantia TD aircon idler pulley
BX HP pulley (numerous)
XU lower engine mounts
XUD tacho pickup
XUD KKK Turbo - rubber pipes
XUD KKK turbo - hard plastic pipes
misc mud flaps
xantia hard plastic turbo feed hose
BX scuttle cover red
BX 16v? air intake panel
misc wheel bolts (non all
misc lighting components ( side repeaters etc)
HP pump mount
knobs (many more)
boot cover for reg plate lights
BX O/S wing shroud
fog light housings for bumper
worn (past best) energy tyre on good rim
random steering wheel (BX direct fitment)
fag lighter
gear box worm drive pickup
full set 405 hub caps
AX boot lining (good condition)
bx lhm reservoir
XUD engine mount
Citroen Genuine tool set 0187-ZZ (Xantia engine tools?)
XU braided water hose
405 N/A diesel glow plug relay
405 Air box
19rd air intake hose (picture shows worst end)
405 temp controls
405 oof console
405 door handle shrouds
405 sun visors (grey, set)
405 diesel engine wiring?
kenwood cross over units (set of 2)
405 estate aerial cable
bx16v steering rack
pug 309 drive shaft
misc XUD engine bolts
Multiple Haynes (more about showing off then offered for sale!)
rear brake calipers
interior parts (misc)
pug 405 stereo control
multiple BX switch units
more interior bits
pug 405 estate bumper and genuine towbar with electrics
pug earth cable (new)
BX pinion valve heat shield
BX rear wiper motor (SOLD)
bx boot lock unit
misc XUD injector pipes
BX track rod end
BX ABS pump
XUD tensioner ad xantia idler
XU engine pulleys and parts
405 dash clocks
BX rear clusters
Ax bonnet (taheti green)
BX Front ABS cable (SOLD)
BX rear arm abs cable holder
BX rear boot lock button
Old school / collectable Hoover vacuum cleaner (working condition!)
misc front BX lights (indicators/head lights)
XUD top mount intercoolers and manifolds
AX washer bottle
misc pipes
AX rear clusters
405 manual mirror (drivers)
AX column switches
405 estate rear cluster
XUD 7 head(inc bosch injectors) NO CAM/CARRIERS
405 head lights
BX front grill
AX scuttle cover
Adikt High alloy wheels (offers around £500)
405 parcel shelf (complete and working)
Xantia TD pipe
Panasonic CD head unit (offers around £60)
XUD Waxstat BRAND NEW
random pulley
x 150
Vanny I need a BX jack for the GT, are you going to stratford?
x 82
Contact:
not any more, was planning on it till i saw my bank balance :( probably not oo expensive to post assuming you dont get one at startford!
x 150
Ok no worries.
TB2
Post by TB2 »
Now this is a very odd-shapen steering wheel you have there :shock:
Carl
1989 16 Valve
Parts needed:
- One black leather headrest.
mountainmanUK
Post by mountainmanUK »
Tim,
I've got a spare jack that you can have for nowt, mate!
See ya at Stratford!! :wink:
(Don't think I've got a handle for it, but I'll have a dig to see if I can find one)
Dave
(probably Sat p.m till Sunday p.m.)
Yeah, what is going on with that steering wheel?? :D
I'll have the 1.9RD doseur off you Vanny - do you know anything of its
history? i.e - is it 'tight?' anyway, I'll ave it,. I'll send you a P.M
x 150
Dave your a legend mate, I do have the handle already and a jack for a CX instead it turns out! :shock:
macker37
Post by macker37 »
lovin that steerimg wheel how much and will it fit 16 v
1990 16v.
Flying is learning to throw yourself at the ground and miss.
Keeper of the site Goat
Contact:
Post by cavmad »
TB2 wrote:Now this is a very odd-shapen steering wheel you have there :shock:
I think it's the bastard love child of an Allegro quartic wheel and a map of the Nurburgring.
Vauxhall apologist.
CitroXim
Sir Jim of the Databases
Contact:
Re: Many preciouses
Post by CitroXim »
Vanny wrote: Citroen Genuine tool set 0187-ZZ (Xantia engine tools?)
I'm interested in that one Vanny. Any further details?
EDIT: Can't tell a lot from the picture as the lid is shut :roll:
Jim
x 82
Contact:
Todd, it came off my 19rd in i think 2002 when i scrapped it in favour of the valver. The brakes worked pretty damn well givent hat it had michelin energie 165s all round. Let me know where it needs to do to and i'll get you a price for postage (i use interparcel).
Macker, yes it will fit a 16v or any other BX, even has the indicator canceler on the back. Make me an offer via PM and its yours (the screws and the cap for the centre are with it, but ot in the picture).
Jim, will get more pictures, it does suggest what engines its for inside, think its for petrol engines, will get more pics early next week.
CitroXim
Contact:
Post by CitroXim »
Vanny wrote: Jim, will get more pictures, it does suggest what engines its for inside, think its for petrol engines, will get more pics early next week.
Brilliant! Thanks Vanny :D
Jim
roy.hassell
BX Jack.
Post by roy.hassell »
If anyone else needs/wants a Jack ( looks new ) for their BX with or without the handle/wheelbrace for £5.00 either way plus postage please pm me.
Roy.
roy.hassell
Wipeer Motors.
Also got Front and Rear Wiper Motors for the hatchback and their mounting brackets for sale. Please pm me.
Roy.
