red Bx estate2.1 d12 in progressss (Romania)
- Philip Chidlow
- x 25
what do you mean ... ? the system had 3 (i don`t know how to say.... in the exhaust system) now it only has the back one, 60 mm is the pipe stainless ,when i have money i will go with 70mm pipes, it sounds good for now ! what i really need is an airfilter , because i now have the original bx 1.9 d and I think it needs some air
jeth ... i wanted to ask .. what`s your speed at 4300 rpm in 5th gear and in 4th? i`m asking because i`m searching for some gearboxes for me... i don`t really know the ratios.. and with what to start
and the other question i will post it in your thread
Citroen BX Estate turbo d12
well ... hellou again , the car moves great ... the only problem was that the water pump .. was .. naughty .. it leaked from time to time ... so it was time for a new one .. with the new water pump came the new belt , and the surprise was ... , the problem was solved by merging the bx mount .. with the xm one .. i don`t have a picture... but it works now great .. and it sits 5mm higher now .. and i also fitted some 17cm speakers in the back ... with some modifications .. because the previous owner (morron if I may say ..) cut the plastic to fit some rubbish speakers
the old water pump!
the old water pump!
hello to all , just finished this today ... a full day of work .. cutting and chopppinng , then painting
from this:
to this:
6mm isn`t much .. but with de 205 tyres .. touched in the interior when at full right or left ! so it clears now , also more space for the new brakes that will come (xantia 2 ones) , and it looks just a little bit nicer now or maybe that`s just me .. loving my car even more
from this:
to this:
