I am about to fit my new heater matrix, to those of you who have done this: Is there a gasket between the oblong flange and the water valve?
I will need to get all parts ready before I start.
Stewart
Reloading my Matrix other parts needed?
TZD 19 TD one of the few
Xantia Td estate, going soft
- ken newbold
No gasket, there are flat surfaced rubber rings recessed into area around the two holes in the valve bit. Although it doesn't appear that it will seal, when I reassembled there were no leaks
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
