I am about to fit my new heater matrix, to those of you who have done this: Is there a gasket between the oblong flange and the water valve?
I will need to get all parts ready before I start.
Stewart
Reloading my Matrix other parts needed?
Stewart (oily!)
TZD 19 TD one of the few
Xantia Td estate, going soft
Stewart (oily!)
ed4ferrets
No gasket, there are flat surfaced rubber rings recessed into area around the two holes in the valve bit. Although it doesn't appear that it will seal, when I reassembled there were no leaks
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
