16txs Estate low mileage
- BXpat
That does look good and with that low mileage should get a few quid. That German Granny BX, almost same age and mileage has gone over €1000 now, but perhaps the Uk punter is less enthusiastic. I would have it , doesn't look as though it's been too 'work-horsed' either!
M
- x 25
Manual actually.M wrote: Automatic = percieved awful economy
Shouldn't be too bad on economy though. Depends how much stop-start short trips you do in something like that. On a long haul it'd be bearable. (as it would even in auto guise).
- x 25
Indeedy, only the 14 petrol is the cheaper, but when you work it out that £5.41 a month difference, having power steering is worth a fiver a month to me as is the extra bit of ooomph.Philip Chidlow wrote:I thought it was all the same for our BXs...M wrote:1.6 = higher tax bracket in UK
Indeedy, only the 14 petrol is the cheaper, but when you work it out that £5.41 a month difference, having power steering is worth a fover a month to me as is the extra bit of ooomph.Philip Chidlow wrote:I thought it was all the same for our BXs...M wrote:1.6 = higher tax bracket in UK
This linky will explain all Phil...
- x 25
It's cos I've never had a 14! Do'oh.
BUT it is still potentially a practical BX estate to consider.
(Spot the BXagon plug coming...)
It would be OK to use on the BXagon Challenge!
PS Even if it doesn't actually have a 'Driver's Airbag'!
M
- Keeper of the site Goat
- x 25
