4x4 Estate needing a home
richardd1652
messerschmitt owner
an exhaust is nothing but some piping, a silencer box or two and a catalyst (if needed). I'd be off at an exhaust manufacturer for one - if I can get one for my 1959 messerschmitt, I could get one for a BX 4x4 in mild or stainless, or even carbon fibre or titanium!Roverman wrote:All 4x4 models suffer the same problems or failure, exhausts are bespoke and unobtainable!richardd1652 wrote:Do they all suffer 4x4 problems or is it mainly from abuse/towing etc?
Richard.
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
JayW
- x 13
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
The 4x4 saloon exhaust is decidedly simpler (imho) than the regular BX one, so it really shouldn't be an issue.
On the cog box side, i think this idea that towing causes the problem is a bit of a red herring. My understanding is that the damage is caused solely by aggressive driving, both hard acceleration, sloppy gear change, dumping the clutch and J-turns.
The flipside is that i've driven one that was very heavily abused yet never skipped a beat. I've also driven one that was absolutely imaculate, well maintained and looked after, low milleage and it didn't last very long at all.
If there was a solution to the cog box problem, and having seen pics of one in bits i believe there is, then i wouldn't be too worried about owning one.
rayfenwick
- Yahoo Messenger: otis_wilbury_ii
Thanks for making my day Vanny... one day I'll get one ...Vanny wrote:If there was a solution to the cog box problem, and having seen pics of one in bits i believe there is, then i wouldn't be too worried about owning one.
Ray
www.citroencarclub.co.uk
messerschmitt owner
in Cambridge, Glos, at Tony Weston's Citroen garage - just ten miles south of Gloucester on the A38JayW wrote:OK, slightly confused... is the car in Camborne or Cambridge?
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
Definately Cambridge, Gloucestershire - Sorry for the confusion.OK, slightly confused... is the car in Camborne or Cambridge?
Will go back round and sort pics etc in the morning.
- Keeper of the site Goat
electrokid
It certainly would, but...A BX TD 4x4 estate would be a great piece of kit
would do very nicely too. I'm seriously taken by the idea unless Doc wants to snaffle it for Smiffy. I had a 2 litre Granada saloon with 106 bhp and that was a fine motor - and 300 Kg heavier !If its a 4x4 estate it will be the 1905cc carb fed petrol 105hp unit.
If you told me it was fitted with a Weber carb as well I'd have to increase my medication
Looking at the drawings on the Citroën TIS the rear diff looks standard enough - is it the transfer box / viscous coupling that go wrong ?
I went to Cambridge of course...
sadly only for 2 days upgrading some software for VAG
2002 C5 HDi SX estate
A diesel has more torque though doesn't it Cav and thats going to equal quicker damage despite slower performance.cavmad wrote:Couldn't you fit a diseasel engine to one though? Ok, it'd be comically slow (in n/a form at least) but would probably put less strain on the chocolate 4x4 system.
I'm sure I have a press release stating that a 4x4 break was made with a 1905 NA diesel. So sure I'd almost bet my breakfast on it.
I think a TD would be asking for trouble, although I still love the idea of a 16V 4x4 with Activa setup.
Since BX's seem to have dried up on the bay then I'll most likely go have a look at this 4x4 on Saturday after delivering 3/4 tonne of Lance rear axle to the farm. Assuming Smaiffy likes the idea that is!
It's certainly handy given that the Westons are 10 minutes away.
