H Reg BX 16v 113k Free to good home Southampton area
Hairbear
I have had my 16V sitting on the drive for a number of years since mildly damaging the rear drivers side door. I have been intending to bring it back into service but have just never got round to it (after 5 Citroens I needed a rest) and now have too many other 'projects'.
I have just started her up and she runs, good oil pressure. Hydraulic pressure OK but pump chattering (I had replaced new regulator etc. but was never quite happy with it). Bit noisy as back silencer now has hole it. Radiator runs up to temp. and fan cuts in OK. Electrics, brakes & clutch all seem OK. Once warm exhaust seemed pretty clean.
Being Citroen red it has faded to many different shades, but haven't noticed any significant rust. I can send Photos of body/endgine/dash etc.
I really need to clear a gap on the drive asap for new arrival so will give her away to anyone who is looking for a project or spares to keep another 16V running. I will throw in some Strongbow if you can do it in the next week !
I would hate to scrap her, but it might come down to me or her !
If you know any one who might be interested and can move her, mail me on [email protected] I live in Hedge End near Southampton.
Cheers Hairbear
Cheers Hairbear
- BXpat
CitroXim
- Sir Jim of the Databases
Sounds to me like it's far too good to scrap or use as a spares donor and is a good prospect for restoration.
Have you any photos you can post up Hairbear?
Jim
- x 94
Hairbear
Hi Kitch
Thanks for the mail, see ur just round the corner - there BX'ers every where. Haven't managed to find how you post photos yet.
Must say the paint looks great in the photos, who says a camera never lies !
Best you look at the beast before offering a home - I'll send some piccies and give you a call tomorrow.
Cheers all
Hairbear[/img]
Cheers all
Hairbear[/img]
- x 94
OK mate, let me know. To be honest, if it's free then I'll take it. I'm not one of those who say yes I'll have it, then turn up and pick holes in it!
I've got lots of spares here, including a pump and a back box so ideally I see returning it to the road as the best solution. I've just broken the remains of one that got pugged so I'm in fighting spirit to save another one!
I did need to shift that, as it was basically a shell, but a complete car I will find somewhere to keep (que phone call to parents!)
I'm a bit worried actually....mines red, has done 113k and regularly visits Hedge End! Maybe I should check me garage!
I'll await your call mate. I can have it out of your way tomorrow night.
Hairbear
- x 94
- x 94
- x 94
Well, in the end tomorrow became today and I've got the car safe and sound back at home now. Big thanks to Hugh for allowing one of us to take the car and give a bloody good go at making it road bound again! A true gent.
Only pictures I have are the ones I was emailed. More of my own later...they'll follow in this thread.
From what I can make out, it was last on the road in 2001! Hugh has owned the car since 1997, and according to the history it's only covered around 20k miles or so since then.
It's actually a newer car than my own, even though it was registered before it! It's a mid 90's spec, so twin electric mirrors and 2 row ECU
First impressions are pretty good, definately better than expected. It has an original remote plip (which doesn't work yet), no dings other than the one in the O/S/R door, a complete bodykit, a sunroof deflector (if thats your bag!) and the interior is in good condition.
Rot wise the A-pillars are good, and the inner wing on the O/S is rot free. N/S looks like it's got some, but doesn't look horrific yet. Bottoms of C-pillars are mixed....one looks new, the other has tinworm but seems solid enough to work with. Only let down area for me is a tricky one.....around the windscreen and up the A-posts. I've seen much worse, but I know it's tricky to put right whatever state it's in, so thats one count against it. I don't know what it's like underneath....could be like cheese! But initial impressions aren't bad.
Engine runs smoothly enough, although only for brief periods before it drops onto two or three cylinders. Could be something simple like old fuel, or possibly needs a few tit bits like plugs, leads etc. Gearbox is smooth and tight.
Brakes aren't functioning very well, but again it's fair game for a car that's been stood. Hydraulics seem ok, but rear spheres are shot. Front's seem ok, although you can never tell it's settled until you get the faulty ones changed.
To cap it off, so far the things that need doing are:
Exhaust cross box - gaping hole in it! Backbox looks tired, plus it clearly needs a ph2 oval!
ABS light on
Speedo doesn't work
Dash bulbs mostly out - easy fix
Replacement O/S/R door
New aerial
Clutch either needs adjusting or replacing - heavier than most, although not excessive. Bites high.
Rust around screen & A-posts - Door mounts on A-pillars are good....N/S is best I've ever seen.
Slight knock from N/S suspension
Misfire from engine - suspect decent service & tune up required, don't think theres anything seriously wrong with it, as when it's happy it's very happy!
General wiring tidy-up - clean connections etc
Other than the above I can't see alot more so far. Obviously the MOT will pull up other things, probably CV boots and flexi-hoses so I'm prepared for that.
My intention is to restore some life into the car, get a ticket on it and find it a decent home. It definately has signs of potential, and if it were not for the rust it could really be one of the tidiest I've seen for a while (after it's got intimate with some cutting compound and a mop!)
Next step is go through the car with a fine toothcombe, list all the known faults and add the sums together and decide if it's worth ploughing on with or not. So far, I think it is but theres alot of the car I haven't seen yet.
Worst case scenario....the car is beyond economical repair and it's broken/recycled in the same way the white one was in order to create a decent spares source. I genuinely don't want it to happen that way, so I'm being positive so far.
Not much will happen in the next couple of weeks or so though, as moving house and packing are priority. Once settled in the new place, I'll crack on with it.
Not sure the gallery was the best place to write all that, but hey ho!
ABS light on
Speedo doesn't work
New aerial
jonathan_dyane
- BXpat
