Replacing diesel stop solenoid
ed4ferrets
Yahoo Messenger: ed4ferrets@yahoo.co.uk
Post by ed4ferrets »
Appears to be a Haynes 1 spanner job but is it straightforward swap or should I be watching out for anything untoward? Picked up a new one today and was rather surprised that it's not goldplated as the price led me to believe :?
'94 XM 2.1TD Break
'63 Renault Caravelle
Post by ken newbold »
If it's a lucas, there's no problem, if it's a bosch :o good luck!
Is there a special spanner to do the one on the Bosch pump? I think it's something like 27mm, but it's a real pain to get a normal spanner in there.
Alastair
Post by Alastair »
I changed the last one with carefull use of a small hammer and a sharp punch. No problem.
Bx turbo diesel 1989
Bx 1.9 Rd estate 1989
Citroen Light 15 1952
Bx 17 TZD diesel turbo 1992
Xantia 1.8 16v
ed4ferrets
Lucas \:D/
'94 XM 2.1TD Break
Re: Replacing diesel stop solenoid
Post by RxBX »
I thought it was probably a 'Lucas' as as there always failing at some stage in their life (Typical failure symptoms i.e.:- Solenoid/rubber valve face/spring/diesel leak between body and ceramic insulation).
That is why you can always get a good used one or almost new from a breaker's yard from any Lucas version diesel that's typically in Citroën's, Fords, Pugs etc. for a couple of quid as I've have on many occasions !
So how much did you get 'Skanked ' for a new one as you stated:-
ed4ferrets wrote:Picked up a new one today and was rather surprised that it's not goldplated as the price led me to believe :?
ed4ferrets
erm........ £29.50 including 10% discount :shock: Why is the rubber valve face /spring not available separately as required :?
'94 XM 2.1TD Break
ed4ferrets wrote:Why is the rubber valve face /spring not available separately as required :?
Because there's a lot more profit to be made on £30 odd quid than on 50p worth of plunger and spring??? :roll:
ed4ferrets
Job done, well happy :D
'94 XM 2.1TD Break
