Windscreen Washer + Roundabouts
roody262
Post by roody262 »
I've done a search but have been unable to find any information. Of the two BX's i've driven i've found that when going round a roundabout the washer fluid simply forces its way out of the spray bar and all over the screen.
Does anyone else have this problem (I'm guessing its a common problem although i could be wrong) and does anyone have any ideas how to stop it?
I thought about maybe swapping the front washer bottle to the other side as this could stop it.
citro-geoff
My Cars: Xantia VSX Estate-146K-1996 (The wifes car)
BX TZD Turbo-317K- Awaiting repair/donor car(broken subframe)
BX TZD Turbo-202K-project car ongoing
BX TZD Turbo-212k-One owner car rescued from being scrapped.
2CV Charleston-101K-One owner car awaiting restoration.
ZX Memphis-185K-Wifes daily driver.
BX washer tube,
Post by citro-geoff »
I have the same thing happening on mine too,and also on the CX when it had a tube.Changed the tube for a couple of on bonnet jets from my local factors. I am looking to mount a couple of Xantia ones below the scuttle cover when I take the TZD off the road to do the gearbox and straighten the front out!!Geoff
1995 ZX Memphis TD Saloon 176k
1997 XANTIA VSX ESTATE-112K(the Wife's!!)
1993 BX TZD Turbo Estate 202k waiting repairs for mot.(Just started to fix it!!)
1985 2CV 100k - waiting full restoration.
It seems to be a design fault, everyone Ive owned has done it.
Dont drive so quickly on roundabouts :wink: Funnily enough, i've not had that problem yet :lol:
roody262
Post by roody262 »
MULLEY wrote:Dont drive so quickly on roundabouts :wink:
Ohhhhh, but thats no fun!
Has anyone tried moving the washer bottle to the other side? This should work assuming its the pressure from the bottle inself pushing the water through. It could however be just the water in the pipes that wants to set itself free.
I have toyed with the idea of fitting jets (1 or 2) in the grill at the bottom of the screen however I don't really want to damage the grill in any way.
if the system was originaly fitted with an inline one way valve and then removed when it colapsed, this used to happen to some of the citroens, i dont remember if the BX had them fitted from new
Most of the BXs I've ever owned have done this. In particular the current GTi. But then I do corner quickly given the conditions are appropriate. :roll: 8)
Move to France.
This has a lot of benefits - it will solve the problem on rounabouts but more importantly you'll have better weather and cheap wine!
Swopping the wiring and feed tube over to the N/S tank will indeed cure this, as will fitting the valve, which certainly both of mine had, but dont anymore.
Another option is to move the wiper so it parks on the drivers side (easy enough to do) or as said above, fit a pair of jets in the scuttle panel.
Post by kiwi »
You know I had forgotten about that problem.
Then again no roundabouts around here for me to test the problem out :lol: Serious corners though and nope have not got the problem.
It seems that both my BXs have got the modification that Doc described, which means it works. Far out though actually something the kiwis modified in the BX that improves things without noticing. :shock:
Now to cure the dreaded blocked washer jet problem :wink:
1990 BX19 TZS Auto 06/11/1989
Keeper of the site Goat
Post by cavmad »
mat_fenwick wrote:Move to France.
That's the best technical answer I've seen in yonks :lol:
Slightly expensive fix but a bloody good idea!
Vauxhall apologist.
Aerodynamica
Post by Aerodynamica »
Odd, I'd never heard of this problem. Cyril doesn't do this.
I got a replacement one way valve from Halfords to fit in the CX and fund that the thing prevented the jets from working (yes it was fitted the right way round!)
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
maybe the scotish water is not stronge enough to get past your one way valve, you will have to add some whisky AKI THE NOOOOO
roody262
Post by roody262 »
I have found a fix (one that has worked for me anyway). Took a trip to halfords today for a one way valve, fitted and problem solved. Proof was in the vigorous testing (driving round a roundabout 2-3 times!). There was a slight drip but nothing close to the previous effect! At last the passengers side of the bx wont forever have water marks along it!
Slight negative in that it does restrict the water flow but this is minimal, and its possible it puts the pump under some extra strain.
Another washer related question : the rear washers don't work, the pump works when tested but when its plumbed in no water appears at the rear! My thoughts are the pipe must be blocked, anyone had any experience with this and would the pipe be easy to replace?
Try the blowing down & sucking technique before trying to replace, i can imagine that its going to be a right royal pain replacing something that goes from the front to the back of the car...
