1990 BX 14 Coil
the_baron
1990 BX 14 Coil
Post by the_baron »
Hi
Got a slight issue with the St Tropez when it gets warm and I suspect its the coil that's at fault. Its fine when cold but starts running rough and misfiring when warm or in traffic.
Can anyone suggest how these coils are fitted? Is the coil mounted by Torx screws or is there an easier way of unbolting it?
Also can anyone suggest where I can obtain a new coil from, my local motor factor is quoting £30 for a new one. Is that about right or rather dear?
Matt
Current Fleet
1990 BX 14 TE St Tropez
1986 Wartburg 353S Tourist
1973 Ami 8 Club Centrafuge
i cant remeber how they are fitted but think they have 10mm bolts,
and try GSF for a new coil, it will be the same as an AX one
CaM
Post by CaM »
the torx screws have nuts at the bottom which aren't too accessible in situ. the bracket's held to the head by two 10mm headed bolts, though, which are much easier to remove.
Mike E (uk)
Post by Mike E (uk) »
Is the coil the square one like on the 16V and GTI?
If so, I have one here you can try.
cheers,
Mike
the_baron
Post by the_baron »
Yes its a square type, unfortunately the car is buried in snow and the doors are frozen shut, so I can't get into it lol.
Current Fleet
Pretty sure its the same as a valver one, if memory serves. It does sound like the coil, although I'd check the fuel mixture too.
Gawd, BXs seem very good at freezing their doors shut, even when it's not that frosty! I'm terrified that one day, the door handle's going to come off in my hand...
A BX tip: a smear of Vaseline around the door seal?
Ah, I'll give that a go once it's thawed out... (not been used for a few days, just brushed about 5in of snow off it!)
the_baron
Post by the_baron »
mmmmmm the joy that is a freshly lubricated BX door seal.... lol
Current Fleet
the_baron
Vac advance unit fitting
Post by the_baron »
Hi all
I have the new bosch vack advance unit now, any ideas how you fit it? Does the dizzy have to come off?
Matt
Current Fleet
