http://www.vosa.gov.uk/vosa/apps/recall ... B900268D1B
Any members had this problem?
You just might be able to obtain a FOC repair.
I’ve never owned a MK1, would this fault apply to both MK1 & 2?
Regards
I remember this fault or should say cynical as to the motives at the time. Just happened to coincide with promoting the Xantia by the main dealers and guess who got to do the checks.prm wrote:Been running through some old stored zip drive back-up info and found this. Appears to be the only recall registered on the BX??
You just might be able to obtain a FOC repair.![]()
Regards
