Who turned out the (dashboard) lights
Boxwolf
Post by Boxwolf »
Ok, the BX has been pretty much behaving itself recently but one small problem has manifest itself in the dashboard lights often not switching on. Sometimes they come on a few minutes after the car starts with a little relay "tick" but more and more often they just don't come on at all.
New relay needed?
1992 BX TXD Turbo
Post by ken newbold »
Possibly, have you checked out the dimmer mounted under the steering shroud? These have been known to fail.
Boxwolf
Post by Boxwolf »
I would, but there is not one there X) just the little hole it goes in. I think it has either been bypassed long ago or just never had one.
1992 BX TXD Turbo
Take a look inside the shroud then, there should be 2 wires connected together, apparently doing nothing else. :)
Boxwolf
Post by Boxwolf »
ken newbold wrote:Take a look inside the shroud then, there should be 2 wires connected together, apparently doing nothing else. :)
I found a rheostat in there, cable tied to the steering column and set to max. Turning the dial revealed the solution to the problem; the rheostat was dodgy, the lights going off for every 1mm of turning it, and recently had been dislodged such that it was leaving an open circuit. Luckily I had a new rheostat from RXBX from when I ordered somethng or other related and the only electrical problem I have had with my BX is now sorted :D
1992 BX TXD Turbo
