17 TGD on Ebay
richardd1652
17 TGD on Ebay
17 TGD in Bournemouth at a garage .Asking price is £395.
Item number 110547593750
Low miles,nice colour.
Ive emailed asking condition etc.
Richard.
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
- x 27
- x 27
Although at only 63k, who ever buy's this need's to budget for a pair of rear radius arm bearings/overhaul in the near future (Unless there's proof of them being overhauled recently) as when the BX's reach the 65-70k mileage mark is about the most that can be normally expected from the rear radius arm bearing's (from my experience) plus the standing/low useage can bring out other problems too ultimately when put into daily use !
Even so it's look's a decent/nice BX for the money for some-one, good luck to who ever find's it a home
richardd1652
Yes as the 1760cc n/a and 1769 cc engines are different, you would be better off buying a complete car as a donor, but as that ones done such little miles I would leave it alone and just allow yourself more time!scarecrow wrote:Would retro-fitting a turbo be very complicated?
In a nutshell 'YES' don't even bother as the N/A diesel engine would probably blow to pieces in no time, as the piston's/con-rod's/crankshaft are uprated on the 1.7 TD's plus if you were to inter-cool it too, you'd have all the ducting/exhaust and then the gearbox/drive-shafts etc. to sort out to make a proper jobscarecrow wrote:Would retro-fitting a turbo be very complicated?
