Wheel bolts
- x 25
Wheel bolts
Would GTi alloys and 16v alloys share the same bolt size/type? I know they are different from standard, but not sure on this point...
- x 94
Can't see why not.....the 16v has the longer flat faced Speedline type bolts, the same as used on the Xantia Activa and Saxo VTR/VTS.
The Peugeots seem to use a flat faced bolt which is shorter but with a bigger head....thats the only two I know of and can't imagine the BX using that, so yes I would say, seeing as the GTi wheel is a 16v wheel with a slightly narrower width I believe?
Mike E (uk)
- x 25
