Low Mileage 19TRS Auto
richardd1652
maxgreenwood
- x 27
maxgreenwood
Hi Phil!
things are good although i just sold the TZDturbo estate. A Sad day but i suspect i might just own another BX in the future. It went to a good home, the guy has about 6 others including a showroom condition 16v with about 40k on it.
What made the decision for me in the end to stick with just the XM was that its become a valuable listening environment for music and stuff i'm working on. V quiet and the BX without some serious soundprroofing would never be as good really. + those doors are not the most solid of speaker mounting material.
I spent along time debating it though, which one was going to go, mainly because the BX was so fantastically economical.
'90 16TZS (m), White, 86k
- x 27
rayfenwick
- Yahoo Messenger: otis_wilbury_ii
Hi Max. A bit OT this (apologies): Have you upgraded the sound system in the XM? If so I'd be interested to know what you've done.maxgreenwood wrote:....the decision for me in the end to stick with just the XM was that its become a valuable listening environment for music and stuff i'm working on......
Ray
www.citroencarclub.co.uk
Linegeist
Gibbo2286
richardd1652
Linegeist
I'd suspect that clock too. I got shot down in flames a few months back for sounding a warning on misaligned odometer drums and I got told "They all do that". <SOB!>Gibbo2286 wrote:I'd query the mileage on the car, mots only start at three years old and that clock looks doctored to me, I'd like to find the pre mot history. Gibbo.
Well, my Athena's odo was just like the one in this pic. Since owning the thing, all the evidence (bearing wear, carpet wear, bore wear ..... and the scratched-up speedo rear) points to the car having 'lost' about 100,000 miles early in its life (before checkable MOT mileage records came into being).
People get up to all sorts of tricks to make a car look low-mileage, from fitting new pedal rubbers to bolting on new steering wheels to get rid of the well worn rim of the original (I even found the 'as new' Ebay steering wheel that my Athena had had fitted to it just before it went onto Ebay itself
Odometers are very difficult to change and still keep all the numbers lined up - they're made that way - and, back when I used to examine cars professionally for the RAC, this kind of misalignment was almost always a clear indication that a previous owner had been into the dash with a small-bladed screwdriver in the search for more market value. Checking (when I could be bothered) inevitably revealed abrasion marks on the speedo/dash securing screws......... and I used to see several of them a week, it was that common.
So, I'm right with Gibbo on this one!!!! That mileage is highly suspect IMHO...
We had a BX 19TGD from brand new and the numbers were never spot on and the more miles it did the worse it got, my 16TRS has done a genuine 43,000 with mots and history to verify and they are a bit wonky too. The only ones that line up perfectly are on the mk1.
Even so if the mileage is a bit suspect its a rare beast, I hope it finds an enthusiastic home.
I find giving the binnacle a good few hard taps as it clicks over to the next thousand miles helps it along and they normally line up well.
maxgreenwood
yea suspicious mileage, you'd really need to look that car over.
yeah i love BXs. i might get another. not yet though. Quite fancy a diesel auto for some reason.
Phil you're a hardened BXer! 'convincing package'I must say the XM is a convincing package.
It had an aftermarket Kenwood CD player in when i got it which sounded great - actually a bit smoother on the top end than my current one, which is also a Kenwood, but i went for the one with a USB input on the front so i can easily plug in an iPod and my portable recorder which has usb. Pretty handy. It also charges them both so i never need to at home. I also wired in the steering wheel controls for Kenwood, which works for the iPod and the recorder. No mods to the speakers though, they sound good.Hi Max. A bit OT this (apologies): Have you upgraded the sound system in the XM? If so I'd be interested to know what you've done.
