New Carb
New Carb
electrokid
Post by electrokid »
Yep - that's the right one...
Guess what I've been looking for this evening :-)
2002 C5 HDi SX estate
god?
docchevron wrote:god?
enlightenment?
electrokid
Nope - God is relatively easy to find despite the limp-wristed efforts of 'plonker' Dawkins et al.
No - I'm looking for a Weber 34DRTC or 34DRTM preferably 14/100 W147/50 but can modify to suit. I will achieve further enlightenment when some kind hero sells me a decent carb :-)
Linegeist
Post by Linegeist »
Well I've just bought (and fitted) a brand new Weber - and it needs the laying on of hands and anointing with something more than just oil .... it needs something that cures a huge flat spot as it comes off idle. :(
It's mucho fun pulling out of junctions .... :shock:
electrokid
That sounds like my 2 litre granny - but then I set it up like that :-) I remember pulling up to a T junction behind a learner - the learner pulled away very nicely - and I stalled the motor :oops:
The ideal setup for a Weber means that you should be able to stall it very easily by letting the clutch back very slightly on tickover to stall it - in other words tickover has very little power - only there to keep the engine running and nothing more.
What I found was there was a 'dead spot' in the throttle linkage itself - it needed to be moved a half-inch or so before any movement happened at the carb - this could be due to a number of things - on the granny it was due to having a return spring on the pedal as well as on the carb.
If your flat spot is due to that then it's likely that the carb is spot on and it's a case of getting used to the dead spot in the linkage - if not then my little red Weber book is needed to help with setup - can't find the **^*$ thing at the mo.
I've just won the Haynes carb book on fleabay so for when that arrives... what's the type number Bob ?
