V. Cheap bx 14 Preview Berline London
White - looks okay - owner says it needs a tune-up. I reckon it might be had for a couple of hundred if you're cheeky
EDIT: http://www.gumtree.com/london/63/667480 ... 438-london
- electrokid
Well done Richard. I agree with Brian, it sounds like Carb problems. I thought it looked in damn fine condition and would have snaffled it if I had a farm
Edit: I do indeed Brian, But mine is only really a problem starting when hot (in hot weather) and just lately I've noticed it starts okay in the cold mornings but dies after a couple of seconds for the first three attempts, then it's fine! It's galvanised my resolve to get the Weber reconditioned and then slapped on in place of that nasty old Solex.
You may recall from previous "technical" topics that the owner is a member of the forum.In talking with Simon it has deeper issues regarding smoking and he feels it may be the head gasket at fault although rings/stem seals etc have also been mentioned.It was on Ebay previousely and i missed out ,but i bid what i thought it was worth etc, anyway we will see when it gets here as to whether a top end rebuild/another lump etc is the order of the day but its a bonny thing with loads of T&T .
I will report back in due course,Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
Oh - I do remember now Still if you can rustle up a decent fix it will make a lovely car. The 14s are underrated, in my opinion. They are lighter and more responsive to drive and there's a lot more space to work in the engine bay. But I'm preaching to the converted.
Having said all that, I would love a phase 1 19rd
Yep no problem, I love the little 14,s. Im not into razzed up Valvers .They have a purity to them and apart from obvious dissadvantages like no PAS,and running out of legs on the motorways, they have a punchy little engine and with there low gearing are great for the hills and country lanes round me in Yorkshire.Pictures on arrival.
Richard.
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
- citsncycles
Mine seems quite happy cruising at 80mph all day (in France, of course, milord ), but it does start to drink the fuel a bit at that speed! A good balance of speed & economy seems to be 65-70, which is why I still prefer the GS for motorway work - it seems to use the same no of gallons per hour whatever the speed you travel at
- Stinkwheel
PAS a disadvantage? Hmmmm i see it as a bonus, nothing to go wrong there you seedissadvantages like no PAS,and running out of legs on the motorways
As for running out of legs, depends, as citsncycles says 80mph is happy. Mine will do over a ton if you want it too, and happily, but really wants another gear at that speed. (all tested on local airfield occifer)
I actually consider it the perfect daily BX as its light and peppy unlike the 17D i once had, which was great on fuel but SLOW!!!!
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
