Cheap 19TGD
Cheap 19TGD
http://cgi.ebay.co.uk/1992-CITROEN-BX19 ... 1e5fe00606
Fully functioning 19D with a years mot for £250!
Hasn't that one been mentioned here before?
Yes it's one of Richards.
My favourite spec too 1.9TGD with the all important PAS. This would make a great base/improvement car especially with those miles on.
Post by RxBX »
citsncycles wrote:Hasn't that one been mentioned here before?
Quite correct Mike !
Tim, It's THIS one of Richard1652 which made £220 (Reserve not met) the last time he listed it !
Defender110 wrote:Yes it's one of Richards.
My favorite spec too 1.9TGD with the all important PAS. This would make a great base/improvement car especially with those miles on.
Kevan, What would you do though with the unusual Hybrid roof bar's (Well the holes that may be left behind) if you removed them ?
richardd1652
Post by richardd1652 »
Yes its mine.I was away all day today and couldnt get back to peoples questions before it finished.Oh well if it doesnt sell at this money,firstly it does make me wonder what the point of testing it rather than stripping it is.Its never going to worry Tim at the next Concours event but it has an excellent engine/box and apart from a little play in the track rod end (advisory with test)it drives like it should.Heater works and even the glovebox is in tact. It doesnt look bad really,just the usual scars of 18 years use.
Really i should run it for 12 months then decide its fate but i cant keep all of them.
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
No you couldn't really weld them without warping the pannels, a much simpler and very easy repair;
Cut a small plate of thin steel, ally or plastic and put a dollop of body filler on it then push this plate over the holes from the inside of the panel, whilst holding it firm with one hand smooth out the filler that has oozed through the whole on the outside. Leave it for 1/2 an hour for the plate to stick solid before sanding the filler smooth. You will probably have to apply another thin skin of filler or stopper and re-sand to get an invisible repair once painted.
Sold!
Roverman wrote:Sold!
to you?
Post by RxBX »
to you?
Kevan,
I don't think it's Tim that bought it, but I know he'd had a bid on it :wink: Best maybe ask Richard ?
richardd1652
Sold to a zero rated Ebayer so here starts the circus.Theve not made any contact prior to or after purchase so i am not holding my breath but it does state in my terms , contact to be made within 24 hours and collected within 7 days so if they dont come forward (usual ebay bollocks insues etc)but i will not be re-listing, and shall keep maybe? but I will keep you posted.
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
Not to me sorry, if it wasnt for that roof rack I would have, i know its cosmetic but...
Keeper of the site Goat
Post by cavmad »
Seriously tempted by this (if the 'winning' bidder doesn't show up) just need to check the funds. I need a reliable diesel in my life after this heap of shit Passat.
Vauxhall apologist.
luckily I'm not in the need of another TGD but there is a strange magnetism about this one. I think I would keep the roof rack on, it adds to the quirkyness :?
richardd1652
Cavmad, You can have 1st call if he doesnt come for it.He has made contact (sort of) but doesnt fill me with confidence.
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
How come you didn't add the filter which can sort out anyone with low levels of feedback, it stops them from bidding in the 1st place & wasting your time :cry:
