Well, the return plastic in my security valve has gone and the car pissed all the inside of the valve and all the LHM.
Is it normal for this component to let go?
Best Regards,
Rui
Security valve
PinhU
Security valve
Citroen BX 16 GTI 8v (XU5JA)
RobC
- x 30
its usualy the short length of conecting rubber pipe that perrish's and splits,
and the usual repair if there is enough length is to cut it back a bit then push it back on,
this can also fix it if the rubber cant grip the plastic spout of the safty valve,
PinhU
PinhU
PinhU
