The front struts on the TZI are shagged, they stick and groan and generally spoil the car as it rides very poorly indeed, which is a shame as the rear had new arm bearings and spheres last year and is smoooooth as silk!
Before I end up mortaging mysel to pleides I though I would ask if anyone has a set of a great used ones?
I have done the lubrication tricks on the struts and also with the return pipes in a jar of LHM and its made it a BIT better but they still need changing.
Thanks
FRONT STRUTS
FRONT STRUTS
- x 27
- x 27
R Edwards & Sons (Cit breakers/repairs)
Oak Lodge
Buckwyns Chase
Billericay
CM12 0TN
tel 01277 651486
[email protected]
Also you can make an online enquiry.
http://www.edwardsandson.co.uk/online-enquiry.html
Oak Lodge
Buckwyns Chase
Billericay
CM12 0TN
tel 01277 651486
[email protected]
It sounds worth going for Tim as long as you can be sure that you get the new ones fitted to Phil's old BX. After all, I paid about £80 from pleides for one recon strut a few years back and I think they have gone up to well over £100 now.Roverman wrote:Had a reply back, £100 plus carriage, will have to wait a bit longer I think!
- x 27
Stinkwheel
Edwards will happily supply you with good used struts if you ask them, i bought one from them in about march, 40 quid i think it was.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
