Mk1 BX 19RD Estate RHD! A new home
It may be worth looking at the rat look scene, they love keeping something looking like this when whey aren't attacking panels with a grinder in a poor attempt to age them. I believe one method used is to spray a clear lacquer over everything, effectively sealing up the imperfections and at least slowing the decay. With some of my old bikes, they get a wipe over with an oily rag to keep them protected, although as they spend most of their lives indoors keeping the weather off is less of an issue.
I'd have loved to have left the GS in the condition I got it in, but the decay in the doors and some other panels, together with the fact that it lives outside meant that I decided I had to do something to keep it on the road long term. On the other hand, when I've finished it my 2CV will look like a project someone is about to start
Not a bad plan Mike.
Changed the fuel filter today. The housing and filter were very icky.
Net result? Not actually much difference. Still feels a touch hesitant when giving it the beans. Went a bit radical and lobbed £6 worth of petrol in before filling with diesel. It felt a little better on the way home.
The tickover still seems a little low though. Seem to recall we meddled with that when we collected it as after a 3 year sleep, it was a little reluctant to tickover properly.
Still having starting issues from cold as well. Huge clouds of smoke and heavy misfiring, even after three or four bursts of glow plug. I suspect the plugs have had it. Pretty sure I ended up swapping a set last winter - not exactly fun. How can something so visible be such a pain in the arse to access?!
I did wonder if there might be an air leak on the induction side of things. I imagine that'd give some of the symptoms I've been having. Any obvious places to check? Starting when hot, or even when left for a few hours, is always instant.
Well Ian,
since i did the job on Sophie by replacing the entire fuel filter system she runs so much better. I wonder as you said that there might be air getting into the fuel supply?
Having fixed the problem she is such a different motor to drive.
Wonder if you could bypass the system temporarily to prove it one way or another?
All the bits are getting old now, rubber pipes, washers and diaphrams etc, could be just a simple fix.
Just keep her on the road bud, as best you can. As is what i intend with Sophie, not going to run a concours motor.
Good luck bud.
Good luck bud.
Sodding weather. It was nice and dry today, so I risked a drive to the next village in the BX. I've not been driving it much lately because the wiper is doing a good job of wiping the plastic trim at the base of the windscreen. Thanks to Royal Fail, a replacement wiper linkage is currently stuck somewhere in the ether.
Typically, it started raining before I set off back home. Wipe THUMP wipe THUMP. Irritating. Also, there's a pronounced wheel wobble when turning right and hitting a bump. I suspect this is the duff track rod end that Mat spotted last time we got the spanners out.
Driving the BX is still rather too much like driving a convertible. Wind howls in all over the place! It should hopefully be going in for much-needed welding and a replacement tailgate next week. A set of doors is next on the agenda, especially as the passenger one no longer likes opening...
The BX has gone in for work. A truly horrible, wet day that saw me fitting new glow plugs in the pouring rain. I did the two easiest ones (middle pair) and decided I'd had enough of that for a game of soldiers! It now at least starts first time, albeit in a rather smoky manner.
Looking forward to getting it back, but there's a hell of a lot to do. I've decided it's definitely down on power. It even sounds slightly strained just revving it in neutral. Not sure what to do next to try and find the fault. It's had new fuel filter and a cleaned air filter. Could it be gummed up injectors? An air leak?
Plenty of time to think of possible things before I get it back in early Jan!
Really looking forward to the "big" meets next year as i hope there will be a really good turnout of Mk1,s.
Think yours looks brilliant as it is but like youve already said, how to keep her from deteriorating if she sleeps outside.
Richard.
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
Have you checked the throttle is fully opening, the cables stretch over the years and need re-adjusting. When you put the pedal fully down (without the engine running) check that the throttle lever on the pump is fully opening to it's maximum throttle stop screw.Dollywobbler wrote: I've decided it's definitely down on power. It even sounds slightly strained just revving it in neutral. Not sure what to do next to try and find the fault. It's had new fuel filter and a cleaned air filter. Could it be gummed up injectors? An air leak?
I don't think it's a throttle position. Even holding the revs at about 3000rpm (no rev counter) it sounds hesitant. It can't be that bad as I've had an indicated 75 out of it. I do always seem to have my foot mashed to the floor though, and I don't recall my old one being like that. I met The Green Tiger briefly yesterday - I should have asked for quick reminder spin!
- My Cars: LOTS!
- x 114
