Here's the situation I can't afford to replace the front wheel bearing ( drivers side) at the moment it is making quite a bit of noise. I was wondering is there any way that you know of whereby I could pack the bearing with grease to quieten it down ? until I can find the funds to replace it.
Kev
front wheel bearings
tzd
It isn't just a car it is a BX and it's my BX. Long live the BX.
sdelasal
rmattila
Front wheel bearings cost around 20 euro here, and for 38 euro you can get a full SKF front wheel bearing kit for a BX. And I don't think it's too bad a job to do by yourself, if you just can borrow someone's hydraulic press for a few minutes. Surely there's someone around with one?
Quite a straightforward job:
http://www.rmattila.com/images/remontit ... in_vaihto/
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
- x 117
All BX 16s and above including diesels have the same hub. The only difference is the ABS fittings and ABS hubs will fit onto either an ABS or a non ABS car and vice versa.
Bearings are cheap on ebay 12-14GBP and as Ken says find a garage with an available press and that is all it will cost you or pay a garage for an hour or two's work and jobs done.
There is nothing worse than a noisy wheel bearing. I changed all twelve of mine three years ago and the cars are so much quieter now.................Except one of the fronts has just gone noisy again so I will have to change that again soon.
Actually I keep a spare set of hubs with new bearings in ready for just such an eventuality so all I have to do is swap it out with the noisy one and change the bearing at my leisure.
tzd
it is a diesel with abs and turbo. I wish I had the funds to buy the bearing let alone get a garage to change it.
kev
kev
as others have said just find a good S/H front hub and swap it over
BX bearings very seldom fail so maybe you are not doing the hub nut up tight enough,Jaba wrote:Except one of the fronts has just gone noisy again so I will have to change that again soon.
