for my unwell 16TZS.
I can't drive it now it's so smelly burning oil. Probably the piston rings the garage reckons. Oil breather is fine, not blocked.
I had a clutch fitted recently and cambelt and octopus + two new (re-con) struts and spheres all round, so i'd like to save it. I do like it.
Wanted: New engine 1.6 carb or similar petrol
maxgreenwood
'90 16TZS (m), White, 86k
Willy
Mike E (uk)
These cars rarely wear out their rings, are you sure it is not just the valve guide oil seals?
These can go rock hard at only 80,000 miles in the 8v petrol cars.
Head off to replace, but easier than an engine change for most people.
Mike
Mike
sdelasal
Max - does it smoke when you're driving along...? Or does it smoke when you've been decelerating and suddenly hit the gas pedal? If the later, then it's the valve seals - simple(r) to fix. If the former, then rings. Did the garage do a compression test or a leakdown test? - that should shed some light on the problem. Compression test should take a garage no more than 15min and is as simple as changing spark. If compression is low and a tablespoon of oil cures it then the rings/bore are shot.
Mike E (uk)
Yes, a compression test is a good idea.
Mine smoked as soon as the oil had warmed up, 3 mins after starting the car, and then made blue smoke continually.
New seals and it ran very clean indeed.
Mike
Mike
the fact it's knocking from the bottom end aswell though and I can see the appeal of just changing the whole power unit, since, unless your able to strip and rebuild an engine yourself, it's most likely easier to throw a whole good engine in. If Max was nearer, then no probs, I'd do it for him, but it's a bit far for me!
maxgreenwood
yeah i don't know too much about heads, seals and valves. I might get the compression test thing done. It only smokes when fully hot, although not at idle. It smokes on acceleration or steady throttle up a hill say, doesn't seem to be linked to accelerating after deccelerating.
Mat Fenwick has kindly offered to help with an engine swap, and he's not too far from the Irish sea.
Richard has a 40,000 mile 1.9 carb engine, albiet er.. in a car. It sounds like there is someone near him also that could help with an engine swap.
I like the idea of the 1.9, is the fuel economy bad compared to the 1.6, and what about gear ratios?
JayW
- x 13
Mike E (uk)
philhod
The engine out of my old meteor was on an engine stand in the college workshop.
It was a 16 and in good order, it's probably been apart and back together a few times
There was nowt wrong with it as I was converting it to 19 diesel at the time.I'll check if it's still useable and get back.
If I took it to Mat's in N wales, that's not too far from Holyhead if you nip over.
There are only very minor differences in gear ratio's/ final drives. Even your speedo would still be in calibration
67 and still rockin (but not in a chair)
