rear height corrector.
ace_the_bass
right chaps. im after a rear height corrector for my 1991 19gti.
has anyone out there got one for sale?
car has failed its mot and i need it back on the road asap.
thanks for reading guys
ace_the_bass
Can you get the car to Blackpool? Dave Ashworth is a Citroen specialist and very good. He might be able to repair the height corrector and/or any leaking pipes. His tel no is:-01253 696294
Very helpful and knowledgeable.
Is it leaking from:ace_the_bass wrote:its leaking and therfore he has decided to fail it
1) the HP Pipe unions
2) the LP return
3) Out of the body from under the black cap
Only (3) means you need to replace the Height Corrector
(1) may only need tightening up the union or replacing the rubber seals.
(2) a replacement bit of rubber pipe.
2) could just require the short rubber conecting pipe cutting back and re/fitting (10min job),Way2go wrote:
Is it leaking from:
2) the LP return
3) it is not actualy the H/C leaking but just the diaphram and possibly the outter dust cover,
both of which can be replaced without replaceing the hole unit,
ace_the_bass
all the diaphrams and dust caps can be bought,
here is price's and part No.'s of the parts if they are still availible from citroen,
5410408 CORRECTOR CUP 3.36 GBP 4.03 GBP 4.03 GBP
5410407 CORRECTOR CUP 2.88 GBP 3.46 GBP 3.46 GBP
5410406 AJUSTER RING 2.69 GBP 3.23 GBP 3.23 GBP
5410732 CORR DIAPHRAGM 3.40 GBP 4.08 GBP 4.08 GBP
ace_the_bass
you realy shouldnt need to replace the hole thing, as the usual thing they suffer with is being cloged up with sediment, this will wash out with petrol very easy,
just out of interest were did you get the kit from and how much was it,
ace_the_bass
You surprise me Citronut - Are you sure?citronut wrote:all the diaphrams and dust caps can be bought
I tried to buy the dust cap from several Cit main dealers back in 2003 rather than replace the whole thing, all had no stock on the shelf and were told by Citroen that it was no longer available then and that a height corrector requiring these parts in future would need to be replaced as a complete unit.
Can this be the first sign of deleted parts being re-manufactured?
i did say if they are still avalible,
but i see ace_the_bass has aquired a kit from Malcolm Lockwood, so there are still some about,
spoz id best rumage amongst my bits and bobs to see how many S/H diaphagms and dust cover i can dig up if they are going to become scarse
KevR
Already posted on AtB's other thread before I saw this. I've got a few spare height correctors from a 16TRS and a 17TZD.
Can anyone tell me:
a: Are they the same for all BXs?
b: Are they the same front and rear - they look the same.
Can anyone tell me:
