OK NOT A BX BUT.......
x 174
A good friend of mine has a ZX 1.9 TD that was her mums from about 12 months old, done about 120k miles and has been regularly serviced, however it failed the MOT on welding (not sure where, but intend to find out) and discs and pads (new ones supplied with car)
They can’t afford to get the welding done so it’s for sale spares/repair. it runs well and the pulls like a train.
It has the same type of alloy wheel as a ZX Volcane, the body is fair, no rust but a few bumps and bangs!
£200 ono.
car is located in Coalville, Leicestershire.
The car IS taxed and can be bought separate.
Stinkwheel
Post by Stinkwheel »
Id be interested to know what the welding required is Tim, as and when you find out.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
x 174
Stinkwheel wrote:Id be interested to know what the welding required is Tim, as and when you find out.
Will do mate, hes not mechanically minded so it will be probably direct from the fail sheet.
x 174
NSF shock absorber mounting
NSF sill
NSR sill
OSR sill
OSF Subframe
Wiper blade (Ive got plenty)
Front Discs and Pads (supplied)
Handbrake Effeciency Low.
x 174
Any takers?
Stinkwheel
Im out im afraid, i cant be bothered with that much welding, especially subframes, hope it finds a new home.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Sounds like a parts car, Tim TBH. That's a lot of work needed. And that's only the stuff deemed a fail...
x 174
Philip Chidlow wrote:Sounds like a parts car, Tim TBH. That's a lot of work needed. And that's only the stuff deemed a fail...
True, shame really, think he will weigh it as its more trouble breaking it.
..that_ Thats a lot of potential welding and in my experience it only gets worse as you start stripping back! :(
x 174
Defender110 wrote:..that_ Thats a lot of potential welding and in my experience it only gets worse as you start stripping back! :(
True, didnt realise ZX's were so bad, mind you the metal they are made out of does seem very thin. The engines great but its a faff taking it out.
The alloys must be worth £50?
Roverman wrote:...The alloys must be worth £50?
If they're in good nick, yes. And they fit the BX (don't look to bad if that's your thing) although something has to be done about the pin in the rear hubs IIRC.
x 174
Thats easy enough, just replace it with a small screw, I did that when I fitted aftermarket alloys to the TRS (for about a week).
Keeper of the site Goat
Post by cavmad »
Alloys will be worth about £7.00 each weighed in, rest of the car should fetch anywhere between about £130-£185 over the bridge. If it's got a cat that might make a few quid on an internet auction site.
Crushing it is the best solution to be honest.
Vauxhall apologist.
scooters
Post by scooters »
True, didnt realise ZX's were so bad?
on the whole they are not - pretty decently rustproofed but I suppose getting on a bit now - I have the stable mate a 306DT but would love a Volcane TD - however, this one sounds too far gone -
these are worth even less than a 306 these days - lucky to get £400 wth 12 months ticket on it and in good condition. Brilliant cars though - if you can get a sub 100k miler in decent nick well worth it for an early oil burning hooligan
1991 BX16 TGS Meteor (arriving soon)
1996 306 TD
1997 Subaru Legacy 2.5 Quadcam
x 174
I cant say im not surprised its rotten in the sills, I imagine its not had a wash for about 6 years and is used in all weathers, which is a shame when you think her Mum paid probably a good few grand when it was a year or so old. I remember it being mint back then but as of late its just been an old banger.
