LHM tank Y piece
LHM tank Y piece
Oh no, not again I hear you saying!
But I wasn't going to ask what the part number is or if anyone wants one :lol:
It was just that mine has split, and I phoned up our local dealer for a price and availability. He quoted £4.62 and has 5 in stock, so if anyone else is after one then please let me know before Friday. I didn't ask whether that included VAT, so best to assume it doesn't.
Change of colour?
Do you fancy a change of colour, cheaper too! I'm assuming they are the same?
http://www.ebay.co.uk/itm/250900788560? ... 1438.l2649
Even cheaper! But what I didn't know until your link was the internal dimensions as it was listed as a vacuum T piece. I wonder whether the orange ones are made of a more heat resistance plastic? (As it does seem to be a common failing, and the Xantia tanks are closer to the engine).
i think the use of a Y piece there is no good as it angles the two pipes upwards towards the bonnet,
a T piece is far better, you can buy little plastic ones for coupling windscreen washer pipes,
then conect it up with three short lengths of rubber pipe,
bx petrol auto saloon
LHM Tank Y Piece.
Dear Matt.
Nice to talk to you Matt finally, It is very kind of you to ask about these
Y pieces, Is this the same one that sits on top of the LHM tank lid ? if so I
would like to take one if I may, as mine split last week.
Many thanks indeed Matt.
Vince. :wink:
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
citronut wrote:i think the use of a Y piece there is no good as it angles the two pipes upwards towards the bonnet,
Agreed, they certainly weren't designed for under the BX bonnet.
I believe "Y" was chosen over a "T" in order to stop the return (leak-off) LHM from travelling into the vent pipe.
aaah so there was a method in there madness after all,
i have never heard it explained that way before,
i spoz the answer to that is drill a hole in the bonnet to stick the vent tube up through :shock: :roll: :lol: :wink:
Way2go wrote: I believe "Y" was chosen over a "T" in order to stop the return (leak-off) LHM from travelling into the vent pipe.
Ahh! so obvious once it's been explained to you :!: :oops:
philhod
Post by philhod »
:) I know it's a bit over engineered but I've made them out of 5 mill stainless pipe welded together.
67 and still rockin (but not in a chair)
RobC
My Cars: 1991 Citroen BX 16v
x 30
Post by RobC »
I ended up buying one from citroen (they only come in packs of two though, so i have a spare for a fiver if anyone wants one).
trouble is.. the internal diameter's too small! so either my plastic pipes are too thick (can't see why) or citroen have f'ed up...
1991 Citroen BX 16v
RobC wrote:they only come in packs of two
Hmmm, that's strange, as when my wife went in to collect a couple on Friday, they'd already made out the receipt for one, and had to change it as I'd asked her to get two!
It was quite a squeeze to get it over the pipes, but hot water helped. If you still can't get them on I suppose you could open it out with a drill.
Boiling water was the tip that was recommended to me, it should soften it up enough to squeeze on.
BX Meteor
Post by BX Meteor »
I've connected the return direct to the LHM tank via a short straight rubber section. The vent is no longer connected, just sits there with a tie wrap. Not having a vent does not seem to give any problems, or maybe the tank vents round the rubber bung.
LHM Tank Y Piece.
Dear Mat.
Thanks ever so much for the " Y " piece that arrived today in the post has been fitted already and sorted the job out very nicely thank you very
much Mat.
Take care.
Vince. :wink:
