The brushes and slip ring are goosed on my alternator (Valeo A13N181- BX16 Meteor). In addition the rectifier is looking pretty grim as well. Anyone have an alternator for sale?
Also I am looking for a sunroof mechanism cover
cheers
Rich
Alternator sourced - anyone got a sunroof mechanism cover?
scooters
1991 BX16 TGS Meteor (arriving soon)
1996 306 TD
1997 Subaru Legacy 2.5 Quadcam
1996 306 TD
scooters
cheers Andy - engineer wants £50 - if I do it myself the parts add up to about £45 - I called a scrappy I use in Rotherham who do mail order - £42 for a refurb with a 12 month warranty seems pretty decent to me - it turns up on Friday - until then the car has a whopping battery from a Daimler Double Six which should keep me in lights and wipers till then!
1996 306 TD
1996 306 TD
Mike E (uk)
mnde
- Meteor Man
They used to be air cooled with their own cooling fan built onto the front of the battery housing.scooters wrote:until then the car has a whopping battery from a Daimler Double Six which should keep me in lights and wipers till then!
I have a sunroof mechanism in grey you can have if you still need one and your not just selling the car on for a quick buck?, If so PM me your address and i'll stick it in the post.
scooters
Thanks for the offer Defender -
Hold onto it just now - I have an idea I may be able to fix the one that is no longer sticking using cunning soldering iron appliation and a but of judicious bending! If it all goes tits up, ie clip breaks causing hand to make contact with soldering iron and much swearing and pain I'll come back to you.
Obviously anything goes but I have no intention to sell the Meteor - it is my primary transport at the moment and is running very well indeed - I especially like the simplicity and engineering elegance of the package despite the fact the car lacerates me every time I wave a spanner at it!
1996 306 TD
1996 306 TD
mnde
- Meteor Man
Only real Citroens do this. The GSA is very good at this too.scooters wrote:despite the fact the car lacerates me every time I wave a spanner at it!
BX hand lacerating jobs: removing HT leads from sparkplugs, removing rad switch connector from above, tightening HP pump belt jockeywheel adjuster and pivot bolts... from above. Even just removing the oil filler cap was potential for laceration - yep I managed it once..
Mark
This one I have solved by using a weeding tool intended for gardening. The cleft end fits around the front of the rubber SP Cap and the curved leverage part of the tool rests on the intake manifold. Pops off the cap with controlled ease!mnde wrote: BX hand lacerating jobs: removing HT leads from sparkplugs,
Agreed this has the potential. I rock it off as it's so tight, but each time think "what a cr*p design". Can be messy putting oil in too when you get that air bubble blow-back!mnde wrote:Even just removing the oil filler cap was potential for laceration - yep I managed it once..
