Hi anyone got or know where I can get a low speed resistor for the cooling fan. Part number advice very welcome too!
Thanks
wanted: low fan speed resistor
scooters
1991 BX16 TGS Meteor (arriving soon)
1996 306 TD
1997 Subaru Legacy 2.5 Quadcam
1996 306 TD
It's transistor controlled rather than dropping the voltage through a resistor. A bit more information here.
mnde
- Meteor Man
Not sure you need one Scooters, as per my text
(as in - for the benefit of other people reading - the low speed worked fine on this car when I bridged the connections on the connector block, and the terminals of the switch with connector in place - hence I ruled out the resistor as the cause of low speed being kaput).
Cheers,
Mark.
Cheers,
Mark.
if its the heater fan speed control we are talking,mat_fenwick wrote:It's transistor controlled rather than dropping the voltage through a resistor. A bit more information here.
as the rad fan has a big fat metal caned resistor,
scooters
Thanks all...cheers for the text mark good news that. I'll get it changed this week.
Took the car to the jet wash today and gave it a jolly good clean. The only dodgey seal is the near side front door which leaked a bit but only undetermined huge pressure.
1996 306 TD
1996 306 TD
