BX Gearbox
BX Gearbox
Ken has mentiond that the idler gear in my 19TZD gearbox is rather noisy and is probably on the way out, so I need to keep an eye out for a replacement box between now and the CCC 2012. A TD one would be good to give it more relaxed crusing.
So if anyone has a good used one please get in touch.
KevR
On the subject of gearing, if you want to experiment it's not hard (or so I'm told) to swap the appropriate bits from a TD or GTi box to give yourself a longer 5th gear. Haven't done it myself but knew a guy who used to prepare Peugeot rally cars, which use the same box, and he used the shortest possible gearing for the four bottom gears, and the longest possible for fifth to keep the revs down on transition sections. It can apparently be done with the gearbox in situ.
Yes 5th gear can be replaced very easily by taking the end cap of the gearbox without removing the gearbox. (well you could in the Pug Partner vans) Sudden lack of drive in 5th is the splines gone in the middle of the sprocket.
KevR
I have! But a: it's in France, and b: I'm keeping it as a spare!ken newbold wrote: Someone must have one![]()
JayW
- x 13
JayW
- x 13
What are the symptons of the gearbox issue? If its just when changing down from 5th to 4th, just double de-clutch rather than the hassle & expense of changing the gearbox? If its changing up, then i guess it's buggered
