1. Exhaust has a major leak of gases
2. Nearside rear radius arm has excessive play in a pin/bush
3. Nearside rear (sill end) body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mounting
4. Nearside rear (wheel arch) body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mounting
5. Nearside rear (door step) body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mounting
6. Nearside front (wheel arch) body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mounting
7. Offside front fluid suspension pipe leaking
8. Nearside front brake hose excessively deteriorated
9. Offside front brake hose excessively deteriorated
10. Offside front constant velocity joint gaiter insecure to the extent that it no longer prevents the ingress of dirt
11. Nearside front track rod end ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt
12. Nearside front position lights not working
13. Offside front position lights not working
Advisories:
14. Nearside front fluid suspension unit partially deflated
15. Offside front fluid suspension unit partially deflated
Never mind I'll just have to do some overtime to pay back the credit card as I need the car for our lads trip to Barcelona and Munich beer festival later this year.
I've still got a list of minor things to sort out as well - I said I had come back to BX's for the challenge
