Are BX brakes TOO good?
I ask this after coming very, very close to smashing my super-rare BX estate into a Merc Sprinter on a tiny mountain road. My fault entirely - too much hoon - and it was only cadence braking (ie manual ABS) that allowed me to bring the BX to a somewhat skiddy halt with milimetres to spare. I really did think I was going to hit it.
What struck me is that in the heat of the moment, it's very, very difficult to moderate brake pedal pressure to find that sweet point that offers maximum braking without locking up. Modern cars can have brakes as sharp as a BX (and Mk1 BX brakes really are sharp) because they have ABS.
S'pose I've demonstrated that despite it's not-100% engine, the BX still can manage too quick! On the plus side, the handbrake is a hell of a lot better now! Tells you something about how much pedal pressure is needed to make it self-adjust.
maybe you have air in your brake system
The brakes are working fine and as expected Malcolm - they're just very good! Perhaps I'm just too used to the 2CV. Because you need more pedal pressure, it's a lot easier to adjust the pressure to find best braking.
1985 CITROEN BX 19GT C1TBX
2003 Rover 25 1.6i XL L33CHT
x 95
Or you could just drive a bit slower! :wink:
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
Pffft! :wink:
Though I will take it easier on that single-track mountain road in future. :oops:
adamskibx
Post by adamskibx »
If your used to a 2CV, BX brakes will feel inferior for this kind of situation. I have driven many types of cars, but the one with the most progressive brakes where that "sweet spot" can be found easiest was a Dyane. You could pick a point on the road and know that you can stop before it. I once had a fright in my Dyane when hurtling down a fast windy mountain road, and a T-Junction came out of nowhere. I thought I was a gonna, but the Dyane just stopped.
I believe that any Citroen with high pressure brakes are too good, but only because of the number that seem to be shunted from behind!
x 95
Even compared to the modern stuff I drive the BX brakes are impressive, I find the Mk1's to be even sharper. Mind you I dont hoon around single track roads................. :lol:
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
BX Meteor
Post by BX Meteor »
Anyone ever tried the "mushroom" brake pedal on a Citroen D :?:
KevR
Post by KevR »
I generally agree that the BX brakes are hard to modulate and the 2CV's non-servo brakes offer a more linear feel but it's not just about the brakes... I've found the BX fronts are far more inclined to lock up when the struts are a bit sticky and/or the spheres are past their best - basically instead of the front of the car dipping and transferring weight onto the front contact patch, the suspension doesn't compress and the weight is acting to push the tyres along the tarmac. Especially noticeable when towing a trailer.
the only time i find hydraulic citroen brakes to sharp/fearce is when air is in the system,
what happens there is you loose your first braking presure on the pedel, so when you find some brakes it locks every thing up,
I'm convinced there is nothing wrong with the brakes. They feel like hydraulic Citroen brakes should feel. Lots of stopping power.
Suspension is an interesting call. The spheres are hard and the car has been feeling a bit wayward. Maybe it's time I got them replaced. Well, I know it's time I got them replaced, just waiting for pay day! Full set of spheres including accumulator is my plan.
Mike E (uk)
Post by Mike E (uk) »
There's nothing like a near miss to help you wise up a bit.
Predicting the unexpected is what makes for safe driving.
Takes years to learn that, and even then we get it wrong sometimes.
Mike
Thing is, I'm very used to those roads. It was less about learning a lesson and more about the classic inattention. If you drive quickly, you really do need to focus.
Came through the same section in the 2CV today at a much steadier pace, though I did get the back end airborne on a different mountain road section...
