Which fuel pump?
oilybox
Which fuel pump?
Post by oilybox »
I've just bought on eBay a 1992 BX Meteor 1.9 Diesel, currently on approx 165,000 miles, ....which fuel pump is it most likely to have? Brilliant Bosch? ....or dreaded Lucas CAV?
Also what is the visual difference between the two?
mechanically-minded, technically-gifted,....self-confessed fix-it yourself fan....
more likely to a bosch on the NA, although some had rotodiesel..
my old J reg NA had a LUCAS pump
Discoil
Post by Discoil »
Looking in my technicians handbook
Roto diesel has the cold start cable at the front nearest the radiator
Bosch has the cold start cable at the back nearest the engine
Land Rover Discovery TD5
oilybox
Oil pump....
Post by oilybox »
Good news! .... The Meteor has a Bosch fuel pump!..... Now to have a word with my Burger-van owning mate...
KevR
Post by KevR »
Not sure what the problem with the Roto-Diesels is supposed to be... I've got them on both the TZDs, one of which is at about 200,000, the other at 175,000, and the only problem I've had is a weep from one spindle shaft, cured in five minutes with a new 0-ring...
How can you tell the difference between a roto & a lucas?
MULLEY wrote:How can you tell the difference between a roto & a lucas?
As posted above? :?
Discoil wrote:Looking in my technicians handbook
Aha, didn't spot that, erm, what does a cold start cable look like :oops:
Discoil
Post by Discoil »
MULLEY wrote:Aha, didn't spot that, erm, what does a cold start cable look like :oops:
Should have said :wink: Fast idle speed control
oilybox
Post by oilybox »
Hmmm! My Burger Van-owning mate uses oven chips, so I'll be tapping into the resources of the local chippy for my used veg oil then, it seems..... Not much cash left for fuel (of any sort!) til Thursday, and I want to be out driving my new acquisition instead of looking at it sat on the driveway....But at least I know I have the capability of running it on veg oil....
Discoil
Post by Discoil »
I stopped using chip oil in my motors but use it in strained form as lube oil in the chainsaw 8)
JayW
x 13
Post by JayW »
oilybox wrote:Hmmm! My Burger Van-owning mate uses oven chips, so I'll be tapping into the resources of the local chippy for my used veg oil then, it seems..... Not much cash left for fuel (of any sort!) til Thursday, and I want to be out driving my new acquisition instead of looking at it sat on the driveway....But at least I know I have the capability of running it on veg oil....
Sounds remarkably like you're just gonna nip off down the chippy and pour it straight in! It's a little more complicated than that :lol: :lol: :lol:
