Cylinder Head for BX TXD - 1749cc
silverfox
Post by silverfox »
Been nursing my beloved for a number of thousands of miles - time has come to change the head - small crack somewhere - no oil in water/no water in oil/no power loss/no missing/no smoke -- but pressurises and spits water if 'turbo'd'!
Am in North Wales - will travel but not too far as have no other vehicle to travel in! Ta in anticipation of a miracle! :lol:
Me depressed? Don't make me laugh!
Are you sure it's not just the beginnings of head gasket failure? they do fail very progressively, and can last for thousands of miles while "slightly" blown
and not trying to be picky, but it's a 1769cc engine.
silverfox
BX TXD head
Post by silverfox »
Are you sure it's not just the beginnings of head gasket failure? ***
Thanks for that David - will investigate first but my 'helper' has just suggested that line of approach first. Geoff
Stewart (oily!)
Post by Stewart (oily!) »
The nearest head to you Silverfox is probably far closer than you think, my Sis is scrapping a 405 which has a BX Turbo engine in it :D PM Me if you need it.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
tim leech
Post by tim leech »
Stewart are you not going to take the engine out an keep it?
Stewart (oily!)
Already have two spare motors, space is what I need, that and time, I think the work/life balance is a bit skewed currently, not that Im complaining, just knackered.
Stewart
x 103
I've got two spare heads off the block, and better still i'll be going to llanberis on the 24th of feb so no doubt very close to you!
PM me if your interested!
