1991 BX 19 TZD
1991 BX 19 TZD
Hello though I'd show my face seeing as im now a BX owner thanks to Tim Leech, as after navigating him across France and Switzerland (Badly) for the classic car challenge i bought his car because it performed perfectly. I also bought the car becouse I own a 1988 Citroen 2cv which is in a sorry state so I decided to take it off the road and replace its shell.
I'v owned the BX 3 weeks now and it fecking ace! been so much fun and i get alot of attention, which I think the stickers help.
iv also fitted some hella 181's that i bought of a work collegue, sorta helps the rally look.
Although sunday just gone the BX's decided to scare me buy pissing all of its LHM fluid across its engine, due to a pipe splitting. which i soon fixed that afternoon. I also managed to source some more LHM on a sunday, seeing as i used 2 ltrs to get home, from a local citroen dealer. even if the bottle was a little dusty.
Thanks for reading, I'm sure I'll soon become a regular poster as i usually get up to all sorts of trouble.
George
George
1991 Citroen BX 19 TZD 130,000
1988 Citroen 2cv 126,000
Re: 1991 BX 19 TZD
Very nice, welcome aboard. Do those Hella's not interfere with radiator air flow?
- x 160
Re: 1991 BX 19 TZD
And about time too George ! Glad you found your way, if "navigating" classes as programming the satnav and being in charge of the tunes then fair enough you did a fine job
Re: 1991 BX 19 TZD
Howdy Mr C! T'is a fine looking car. Spot lights really suit it. Can't imagine there's that much airflow there anyway - most of it goes through the bumper, so I wouldn't worry about it (as long as the fans are now working... )
That pic of it next to the Metro could have been taken years ago!
Re: 1991 BX 19 TZD
Hi George, welcome and good to see J644 CRC in safe hands !
So the only interference/affect with the radiator air-flow would be the minuscule amount the two mounting brackets take up
Kevan, it's a TZD 1.9D n/a with a Long-nosed bonnet with only has an approx. 12mm gap between the lower edge of the bonnet and the top of the bumper face (When shut), as can be seen the lower edge of the driving/fog lights are set above the bottom edge of the bonnet !Defender110 wrote:Very nice, welcome aboard. Do those Hella's not interfere with radiator air flow?
- x 160
Re: 1991 BX 19 TZD
I have missed the old girl in the past few weeks as it was such a lovely drive once all the work was done, to do 2300 miles in that time and never once suffer back ache or feel weary is some achievment
Re: 1991 BX 19 TZD
Nice looking car - there's a set of speedlines and a splitter here when you want them George.
- Reluctant BXpert
Re: 1991 BX 19 TZD
Hi George and welcome! That is a very fit looking car.
Hopefully run into you at an E Midlands event sometime, or see you at the ICCCR?
Re: 1991 BX 19 TZD
Doh!RxBX wrote:Kevan, it's a TZD 1.9D n/a with a Long-nosed bonnet with only has an approx. 12mm gap between the lower edge of the bonnet and the top of the bumper face (When shut), as can be seen the lower edge of the driving/fog lights are set above the bottom edge of the bonnet !.
Re: 1991 BX 19 TZD
Yes please thank you for keeping them for me, i get paid on the 25th so will contact you about collecting them the following weekend if thats alright?Paul296 wrote:Nice looking car - there's a set of speedlines and a splitter here when you want them George.
Thanks im loving my bx even more ever day! shall see if i can attend depends how much money i have leftCaffiend wrote:Hi George and welcome! That is a very fit looking car.
- x 160
Re: 1991 BX 19 TZD
Youve got another pay day Buddy before then....will be money well spent, even if there are lots of 2cv's around!
Re: 1991 BX 19 TZD
repaired the little open door thing as the solder had broke and seperated
although the passengers door one wont light up, the circuit is fine must be a bad earth or wire
- x 160
Re: 1991 BX 19 TZD
Probably be the wire inside the door, the OPEN DOOR sensor is connected to the latch not the light switch, its a door panel off im afraid, easy to do though, or you could just leave it like I did.
- BXpat
Re: 1991 BX 19 TZD
Hello George and welcome along, glad you're enjoying your BX.
I like this picture which is one of those ones that make it look like a model car - it must be that blurred sky, distorting perspective. I'm not much of a photographer but how do you get that effect?
- x 20
Re: 1991 BX 19 TZD
If it is the sensor in the door I have one you can have.
