Is a BX front screen bonded in chaps, also is the seal part of the bonding process?, the reason I ask is there some surface corrosion on the A pillars of the DTR which will be attended too but to get at it properly the seal would be better off coming out.
I can buy a sea easily enough
Cheers!
Windscreen Seal
Windscreen Seal
Re: Windscreen Seal
Yes, it is bonded and the seal is fitted to the screen before bonding. You *may* be able to tease the seal out in places, especially if they've been stingy with the adhesive but it'll be the devil's own job to get it back in again. Personally I would be inclined to do a stop gap 'slow down' job for now, until you can get the screen out as it's likely just the tip of the iceberg
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Re: Windscreen Seal
Where can you get seals from Tim?
I've looked for ages but never had any success, there was one on ebay the other day for ooh about 3 hours, until i found it!
Re: Windscreen Seal
Nt shaw Citroen had some aswell as screens
Re: Windscreen Seal
Cheers tim, might have to contact them about a screen, though i think only Mr Fearn has the right glass for the valver.
Re: Windscreen Seal
I think they had a clear screen and a bronze tint?
Re: Windscreen Seal
did anyone track any of these down ( OE with square corners ) if so at what cost
Re: Windscreen Seal
Only clear and green. If they'd had a bronze one I'd have snapped their hands off.Tim Leech wrote:I think they had a clear screen and a bronze tint?
