http://www.ebay.co.uk/itm/citroen-BX-Re ... 41689156cd" onclick="window.open(this.href);return false;
My parts catalogue shows that the part number quoted is for Estates.
Mike P
Rear cylinders NOS on ebay
Mike P
- BXpat
Re: Rear cylinders NOS on ebay
Good spot and healthy bidding. Maybe it would be a plan to advise the seller that they are for estates as I'm sure their largesse would be wasted on mere BX saloon owners! ( That extra 20cm of length makes quite a difference)
barry badger
- x 10
Is anyone on here bidding on these? I fancy them for spares but i don't want to bid against anyone on here. Or if anyone does want them for spares how about 1 each?
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
KevR
Tell you what, if I win them you can have one of my old ones for a spare...!barry badger wrote:Is anyone on here bidding on these? I fancy them for spares but i don't want to bid against anyone on here. Or if anyone does want them for spares how about 1 each?
Winning bid:- £139.57 [ 15 bids ] + Postage:- £9.50 = £149.07
But where would you get another new pair from even for that price !
Did anyone off the forum secure them ?
At least the seller never lost any money on themE-Bay Seller wrote:A pair of Citroen BX rear suspension cylinders,brand new,but purchased in 1999,genuine parts boxed c/w oil delivery pipes! Original price £135.00
JayW
- x 13
Nearly as good as the £470 i got for the pair of NOS front struts a couple of years ago!
themildbunch
nice to have the originals but don't xantia ones fit with a small mod?
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
yup, but again the problem is finding xantia one's at the right price, they are usually around 80sheets each
Are new Xantia cylinders still available? I would have thought they are almost as rare as Bx ones.
Not sure tbh, perhaps we should start canabalising old xantia's??? There are 2 different varieties as well, the hydractive one's (which are no good for the BX) & the non hydractive one's. Visually, i've got no idea how to identify them apart, any ideas?
The Hydractive ones have much bigger pipes to them, presumably for faster response to pressure changes.. But do we actually know that Citroen are no longer supplying BX rear cylinders? I know it's something that's often talked about - back in 2005 when I first changed mine people were talking about difficulty sourcing, yet I had no issues apart from an overnight wait for the second one. I can't recall anybody going to their dealer and being told they are NFP, but I could be wrong.
Actually the seller did lose money on them, we have had considerable inflation since 1999 and the pound then was worth considerably more than it is now.At least the seller never lost any money on them![]()
ghaddon1701
BX hatchback rear cylinders are definately no longer available from Citroen new. The Chevronics centre maybe able to source one though as they are extremely good at sourcing new bits(for a price). They helped me out on trying to Source GTI 8V/TZD wheel trims. Xantia ones are at about £100 each (that is the none hydractive ones). On the Xantia ones, the casting where the union screws in to it is quite a bit thicker than a BX one and has to be filed or machined down before you can fit it to a BX. It doesn't fit through the gap as it were. Or so the nice man at Pleiades said anyway
I managed to get a second hand BX hatchback one relatively easy.
Regards Graham
Regards Graham
So these were quite cheap then? As rare as hen's teeth.
