Cambelt Covers & Intercooler gasket seal required
Hoping someone has either a new set of cambelt covers for a diesel or non knackered 2nd hand one's?
On the underside of the intercooler is a rubber gasket which mates to the metal surface on the engine, for some reason the one that was fitted has gone missing :( Anyone got a spare new one or a 2nd hand one in good nick please?
I need these parts to get my TZD Turbo back on the road again, she's covered in green moss, but still fired up & eventually rose :o :D
Please PM with your beer token requirements, thanks.
Re: Cambelt Covers & Intercooler gasket seal required
MULLEY wrote:fired up & eventually rose
Excellent! That's more than it did when I was 'assisting'. Maybe it didn't like me?
Cam cover gasket should be easily available from a factors or eBay, and the intercooler seal is too! (Actually the latter surprised me, as I was expecting it not to be!)
x 103
MULLEY wrote:Hoping someone has either a new set of cambelt covers for a diesel.
Which type? The older clip on ones or the newer bolt on ones?
I might have some of the older clip on ones some where, probably in storage.
here is price and part No. for the intercooler seal if its still available from dealer
0000036522 CHAMBER SEAL 2.86 GBP 3.43 GBP 3.43 GBP
MULLEY wrote: On the underside of the intercooler is a rubber gasket which mates to the metal surface on the engine, for some reason the one that was fitted has gone missing
have a good look in the dark recesses down the back of the engine
mat_fenwick wrote:Cam cover gasket
WTF? Obviously didn't read properly, sorry :oops:
HaHa, no worries Mat :)
I believe they are the clip on type Vanny, i didn't even realise there were 2 different types? The way you describe them made me think, should a K reg car have the clips or the bolt on's? Pretty sure when i last looked there were clips that i could see. If you do find some in good nick, let me know how many beer tokens :) Cheers
Cheers for the part no malcolm, ironically they are cheaper than the one's on ebay.
Both my K reg ones have clip ons - I've only personally seen the bolt ons in Xantias and ZXs.
mat_fenwick wrote:Both my K reg ones have clip ons - I've only personally seen the bolt ons in Xantias and ZXs.
thats odd as i would have thought by K reg they would all be the bolt on type
I'll go with your greater experience on that one then, you've probably worked on more than I have!
my F reg has bolt on's, but then the engine came from a K plate...
JayW
x 13
Post by JayW »
I was always under the impression the clip-ons were the later ones? To speed up servicing i'd presume?
JayW wrote:I was always under the impression the clip-ons were the later ones? To speed up servicing i'd presume?
you are joking J they slow thing right far far quicker to flick the clips off
thats what J said!
But no, early engines had clip ons, later were bolt on, I dislike the bolt ons. I'll swop the engine plate over on mine at some point and revert to clip ons
the DTR (1985)has a clip on top cover, and it is the original engine.
