....go on then.....who's done it?
Similar to mk2? Cos it looks pretty different up the back of it!
Mk1 dash removal.....
- x 94
Re: Mk1 dash removal.....
Ive done it on the GT when I changed the cable.
If you mean the dash pod itself, its actually easier than a Mk2! you have to remove the plastic "lid" on the roof of the pod (which houses the dials) which just unclips and the screws are underneath it.
- x 94
No I meant the whole dashboard - GT needs a weldathon up the A-pillars and it's a bit close for comfort!
Ahh sorry cant help you, not sure if Artic Steel removed the one out of the 16TRS he owned when he broke that?
- x 94
It's ok, got it out now. Bastard easy compared with a mk2!
Except GT speedo cable in back of speedo. Why Citroen? Why???! Why do that to people?!
Kitch wrote:It's ok, got it out now. Bastard easy compared with a mk2!
Except GT speedo cable in back of speedo. Why Citroën? Why???! Why do that to people?!
They come throught the bulkhead behind the dash from memory.
Yep - that's how it is on Timex anyway - there's enough slack to pull the instruments forward enough to reach the end easily! I have a complete dash assembly that came with the car - I'll take a couple of pics and stick them on here if you want.Kitch wrote:
- x 94
It does, but the plastic clip that retains it to the back of the speedo unit is inaccessible! I'll put a pic up later.
I had the instruments out yesterday, once I had the 4 bolts out I pulled them forward, lifted them up then managed to get my hand underneath them to get to the clip.
- x 94
GT one must be different - the clip is buried inside a plastic housing with a slot in the top a couple of MM wide. Just enough to get a small screwdriver in there!
I remember it being a faff when I did it on the GT, and it was dark and I ended up with less skin on my knuckles than when I started.
Definately different - it sticks straight out the back on mine!GT one must be different - the clip is buried inside a plastic housing with a slot in the top a couple of MM wide. Just enough to get a small screwdriver in there!
- x 94
