Swaps maybe? My StTropez for a 17 Diesel?
Stinkwheel
Post by Stinkwheel »
Hi folks,
Im in a position suddenly needing to do some miles from now on, so the little 1400 is a bit revvy for regular motorway and obviously a diesel would be better.
Does anyone fancy a swap/part ex, my BX for your diesel?
If yes then please PM me and we can swap some details :)
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
Re: Swaps maybe? My StTropez for a 17 Diesel?
Ah. Is she not local then? ;)
Does seem to be the only complain about the 1.4 - short gearing. Wonder if it's possible to fit a taller fifth like it is on the valvers?
They're higher geared than the GS, but while the GS seems able to run at high speed fully loaded without a significant fuel penalty the BX 14 gets quite thirsty.
Upping the gearing will work, so long as you don't want to load it up much, and it may struggle in headwinds and steeper hills. I've generally found that with their lower powered vehicles at least, Citroen have generally already found the best compromise for all round use.
Its a different box from the XU powered BX's i thought?
That's right. You'll need to look at gearboxes fitted to other TU engined vehicles, like AX, ZX, Saxo and Berlingo. Depending on the final drive ratio, one of these may have a suitable gear to swap in.
I expect one off a 1.6 Blingo may help?
Wouldn't that be another XU engine?
Thought the later units were bored out TU petrols, could be wrong.
Just had a look round the net and you're right - never knew that!
You see, its not just flaps and wheeltrims!
1.4 ZX models have completely different gearing to the BX IIRC in the MA gearbox. My ZX Avantage used to do 70mph in 2nd gear!
Ruins the driving enjoyment, but economy was much better than the BX which got worse at higher speeds like you say.
:lol:
Stinkwheel
Well it failed its MOT yesterday on a patch on inner sill and steering rack worn, luckily found a rack on flea bay for 20 plus post, woo hoo!!!!
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Great!
Is that a non-PAS recon rack? If so it sounds like the same people I got the PAS rack for Timex - seems a good quality unit!
