N/s sill
x 138
N/s sill
Post by rutter123 »
Can anyone recommend a supplier of a good quality n/s complete outer sill panel bx hatch. Have seen some on the web for about 20 squids but know nothing of their quality.
JayW
x 13
Re: N/s sill
Post by JayW »
This is the company i've always used and no quality complaints! http://www.carz2.co.uk/citroen-8394-c-69_76.html" onclick="window.open(this.href);return false;
Re: N/s sill
You could try Hadrian panels - I've used some of their panels in the past and they're pretty good.
Re: N/s sill
i called the company in the link above,
inquiring about a Pisssscasssoooo door sill,
very very friendly lady on at the other end and yes they can supply me with the sill,
she said are you sitting down as its quite expensive, all including carriage and VAT is £64 quid,
i said thats not expensive compared to making it up as i go,
ps.
dont use the 0844 No. at the top of the page as you get some very rude twat asking if you want to buy tickets :? :? :? :roll:
click the contact us button and you get an STD No.
BX Bandit
Backslash Bandit
My Cars: Cars
Re: N/s sill
Post by BX Bandit »
A full new sill for £22! Wow, I'll have 5 please!!!
electrokid
Re: N/s sill
Post by electrokid »
I had a ball-park quote for repair to the n/s sill from Carsaver at Aldershot - £70 but I think I might go for a complete sill as well.
2002 C5 HDi SX estate
Re: N/s sill
electrokid wrote:I had a ball-park quote for repair to the n/s sill from Carsaver at Aldershot - £70 but I think I might go for a complete sill as well.
Brian
it does really depend on how far the tin worn has eaten away to if you go for a full sill,
if only less than a third of the sill length has been attacked i would just have a local repair carried out,
as theres no substitute for OE fitment
Re: N/s sill
The paryts of the sills I've repaired have been a simple box section, making them viable for a localised repair that should put most if not all the strength back into the structure, cars with a central membrane in the sill (like the GS) usually need much more metal cut away than expected in order to get at all the rot.
electrokid
Re: N/s sill
Brian
Thanks for that Malcolm: there's corrosion about one third the way along at the bottom edge which will need attention at some time and was the subject of an MOT advisory. But also the guy who did a small weld to cover a hole in the inside surface close to the back end left the chassis plug out out of the rear of the sill and there's a bit of corrosion on the inside at that point - also that area had some welding done this year as well.
Although I've 'passed' my MIG welding complete with samples to show just how bad I really am :lol: (and can now go on to TIG and gas next week) Perhaps I should clear my social diary :^o and arrange a trip to St Leonards :D
